planning on doing a mirage to evo 6 conversion have a couple Q's
Old Oct 27, 2011 | 11:12 AM
RSMike's Avatar
Originally Posted by Evo_mirage22
Hey guys I have a 99' mirage and im thinking about transferring over the evolution VI engine, trans, and if I can find it the transfer case. I was wondering if you could give some advice on the project and if you would be able to help me out with anything else I would need that would be helpful, thanks.
what chassis is it?
if it's 4wd standard, then it's very easy.
If it's 2wd standard, then you need to cut the rear floor out and weld in an Evo floor.
Old Oct 27, 2011 | 08:38 PM
Evo_mirage22's Avatar
Its 2wd, but what does the evo floor have set up that the mirage doesnt? Im not too familiar with that.
Old Oct 28, 2011 | 11:26 AM
ProPilot04's Avatar
I actually don't think the floor will be a problem... but I don't recall. You'll definitely need the Evo Fuel tank though. The Mirage tank doesn't have space for any of the rear diff or driveshaft.
Old Oct 28, 2011 | 11:30 AM
ProPilot04's Avatar
Actually... if you want my personal opinion after going through MUCH of this. Either turbo the 4G93 as its actually a pretty good motor, OR... get the JDM 4G93T (which is a DOHC motor) and run that.
I recon that a proper turbo 4G93T could run in the high 12's with a decent driver.
Old Oct 28, 2011 | 11:24 PM
RSMike's Avatar
Mine ran 12.4 right out of the box...
I would stick with the Evo (4g63) engine, there is so much room for improvement.
Old Jan 22, 2012 | 03:08 PM
I got another question and its been awhile since I've been on but do you guys know if the 4G63 motor requires a right hand drive dash? If so where i could locate one? Also if i wanted to boost it do i need to have low compression pistons? Just any advice i will gladly take, im trying to get it where i can run low 12s, mid 11s and still drive it on the road. Thanks guys
Old May 23, 2012 | 04:55 PM
BrunoBoy650's Avatar
Bump for new knowledge. I am attempting this soon as well and need to know a few things. I know already that the viii motor will work along with the trans and what mounts are needed. I also heard that the t case from a IV-VI would be needed but an Viii can be made to fit with a bit of cutting. Now I've already talked to a member about using a viii/ix floor pan and since it's wide like the Evo V/VI it can be used. The thing now is that what driveshaft would be needed ? If I can fit a viii t case and viii rear subframe and diff, is the driveshaft going to work ? Also what would you do about driveshaft carrier bearing hangers?
-shane
Old May 23, 2012 | 04:58 PM
evo_k's Avatar
https://www.evolutionm.net/forums/ev...o-6-5-tme.html
This thread should have all the info.
Old Jun 24, 2013 | 07:12 AM
Built 4g63's Avatar
Hey guys
I have a CL2A hatch,evo 8 motor,4/5/6 tc and 8 engine loom. I kno 4/5/6 evo loom is plug and play but i would like to use the 8 loom. Has anyone done this before? If i use the 4/5/6 loom what do i have to change? Saw a post somewhere about having to change the intake but i cant find it back to find out why.
3bar_dc2
Jul 8, 2018 03:47 PM
Alchem1st
Mar 12, 2018 03:37 AM
Teal2nnr
Feb 21, 2016 08:31 AM
alex16
Aug 11, 2015 08:18 AM
Scottr126
For Sale - Cars For Sale
May 14, 2010 07:40 PM
