Why can't I achive high boost?
Old Feb 18, 2011 | 09:08 PM
  #31
JohnnyEvo21's Avatar
Sounds like you should have a professional look at it at this point it would probably be the best for everything if you have the money.
Old Feb 18, 2011 | 09:34 PM
  #32
jameswwt's Avatar
Any clue?
Old Feb 25, 2011 | 07:55 AM
  #33
jameswwt's Avatar
Guys,
after i added another 7psi spring into my turbosmart w/g (total 14.5+7 = 21psi) the sound like boost cut / misfiring problem still occur...And im facing a more worst over boost issue...
I still not re-gap my new plugs and will it be :
1) Boost Solenoid problem?
2) Air flow sensor?
Old Feb 25, 2011 | 07:56 AM
  #34
str8kor's Avatar
get a tune, bigger injectors, fuel pump, etc etc. its not as simple as just turning up the boost
Old Feb 25, 2011 | 08:33 AM
  #35
jameswwt's Avatar
Ive tried remapping, running on walbro 255 fp, fpr, w/gate, etc...
Will put in 800cc sard injectors soon...
Old Feb 25, 2011 | 04:38 PM
  #36
sparky's Avatar
What turbo is the OP running?
Old Feb 25, 2011 | 06:07 PM
  #37
jameswwt's Avatar
Hi Sparky, im still running on stock oem Evo 5 turbo.
Should i remove back the added 7 psi spring?
When i slowly allow the boost to build up i dont hv this misfiring or boost cut problem but whenever i full throttle it the problem come...
Old Feb 25, 2011 | 06:32 PM
  #38
sparky's Avatar
I am just trying to visualize a more complete picture of your turbo and wastegate setup. So, do you have the stock V turbo and a remote WG? Am I way wrong?
Old Feb 25, 2011 | 08:07 PM
  #39
jameswwt's Avatar
Hi Sparky,
here a picture of my set-up...
As my Mech have tested the w/gate after added the new 7psi spring and the w/g valve will only start opening on 1.6 bar...
Attached Thumbnails Why can't I achive high boost?-150015_152786088098368_149633545080289_245602_175962_n.jpg
Old Feb 26, 2011 | 05:10 AM
  #40
silkyjohnson's Avatar
I have a evo 4 and I had he same problem untill I upgraded the fuel pump to a walbro 255, and a good tune.
nspyr
26
Jun 20, 2017 02:08 AM
vr4gasmtt
Jun 14, 2015 10:12 PM
SeanV
May 28, 2012 09:17 AM
black_beauty
10
Jun 1, 2010 06:51 AM
evo_dan
May 13, 2002 04:32 AM
