5 speed trans with use 6 speed shift
Old Feb 19, 2011 | 02:02 AM
picco97's Avatar
Hi
I have evo 8 MR
I have planing to upgrade my 6 speed transmission to stage 4 5 speed trans (rebuild and convert 6 speed to 5speed) I saw the TRE transmission website can do it start some around 1400 bucks
so my question is can I use my stock 6 speed shift(surround shift , cable , etc all stock 6speed) to 5 speed trans?
thanks
Old Feb 19, 2011 | 08:03 AM
rong.'s Avatar
no you have to get a five speed cables and such.Search on how to sections has been done many times.
Old Feb 19, 2011 | 08:19 AM
Dragking2189's Avatar
I just finished coverting my evo ix mr from a 6 to 5 speed, you need 5 speed trans & motor mount, shifter base and cables,wiring harness for the trans, you might need a new trimplate which is the piece on the center console that says "EVOLUTION MR" unless you trim it down a bit you can reuse it . hope that helps
Old Feb 19, 2011 | 03:09 PM
picco97's Avatar
motor mount? is it different 6 speed motor mount and 5 speed motor mount ?
i think motor(engine) mount same between 5 speed and 6 speed
does it transmission mount by any chance?
Old Feb 20, 2011 | 09:55 AM
All the other motor mounts are the same between a 5 speed and 6 speed evos, the only one that's different is the one that goes on the trany which is completely different , you need a 5 speed transmission motor mount if you are converting from 6 to 5 speed.
Old Feb 21, 2011 | 01:11 AM
picco97's Avatar
if i convert 6 speed to 5 speed ( remove 1 speed from 6 speed tranny internal)
do i still need tranny mount ? does the tranny housing different between 5 speed and 6 speed tranny ?
does it same durability as original 5 speed tranny after convert internal (remove 1gear)?
Old Feb 21, 2011 | 01:42 AM
ch1215g's Avatar
SUSPECTED SCAMMER
how about you take my 5 speed and ill take your 6 speed? my 5 speed needs to be sent out anyways it pops out of 5th gear... so it would be perfect for you and most likely cheaper! lmk
PeteyTurbo
205
Dec 10, 2024 06:04 AM
Dacats5555
Lancer Engine Tech
Apr 21, 2017 12:28 PM
manthny18
Apr 4, 2017 03:09 PM
Paulevo9
Oct 30, 2016 11:15 AM
TOKYO EVIL
Oct 6, 2015 07:44 PM
