Factory boost cut????
Old Dec 14, 2003 | 12:27 PM
evo8power's Avatar
Lightbulb Factory boost cut????
In 4th and 5th gear when i floor it with the XEDE, i hit like 23 psi sometimes and it only drops to 20, sometimes the car jerks hard back and makes a backfire type noise then goes back to normal, someone said it was a boost cut?? anyone else have this problem???
Old Dec 14, 2003 | 12:28 PM
nebolic's Avatar
I just experienced that problem last night, but my EVO is stock. I experienced in 5th gear, the needle was climbing but it was not smooth it was shaking back and forth. I was on WOT, so i'm assuming its a boost cut,
Old Dec 14, 2003 | 02:33 PM
GTVEVO's Avatar
Yes you are correct, boost cut comes into play about 20 - 21 psi in 5th on a stock car without running any fuel management. Otherwise alot of people are seeing it becuase of the colder weather. Cooler air will cause the turbo to spool up with less rpms because the air is thicker then the ECU cuts the fuel off basically saying your car is overboosting. The best solution of this is to get a new map for your Exede which I am sure is already out or get a EBC of some sort to keep it from hitting anything over 20 psi unless you have some ARP hardware just to be on the safe side.
When you hit boost cut your car will feel like the motor shuts off then back on very quickly. You will know if this is it. If the boost is going up and down with no misfire feeling it is the stock ECU correcting your boost, this is normal but it sucks becuase the stock ECU doesn't do a good job of managing it unless it is reflashed.
Old Dec 14, 2003 | 03:04 PM
JaMa's Avatar
Super AFC2?
I was considering running as much as 23psi to redline, but this post makes me want to reconsider that. When you say fuel management, I assume you dont mean a Super AFC, because I dont know of any way a Super AFC can trick the car into thinking its only running 20psi.
Is this true? If so, it sounds like a damn fine argument to pitch the Super AFC and go with a reflash.
Curious.
JaMa
evo8power's Avatar
thanks, what kinda ARP stuff???
Old Dec 14, 2003 | 03:53 PM
DynoFlash's Avatar
I have a solution for you all
For $49.99 we have a through the mail boost cut revoval
make it $79.99 and we also raise your rev limit at the same time
With this mod fuel cut is never an issue ever again
Old Dec 14, 2003 | 05:54 PM
mikec's Avatar
Al isn't kidding. I have one of his reflashes and run 22psi with my MBC. I don't run into fuel cut and don't have erratic acceleration. Btw, I think Shiv is now offering a similar reflash for around $100.
Old Dec 14, 2003 | 06:47 PM
GTVEVO's Avatar
ARP stuff would be head studs. To run more than 20 psi it is recommended to use some better headstuds becuase the factory ones are said to streach after a while. SAFC will actually trick the fuel cut alittle bit but not enough unless you have bigger injectors so Dynoflash is a much better option and well worth every penny compaired to the other vendors that ECU reflash. The only reason I know what you are talking about is because I ran into the same problem and I will be shipping my ECU off to dynoflash after christmas to get rid of this. Hitting fuel cut is not a good feeling at all.
D1andonlyantman
Apr 26, 2016 05:03 PM
D1andonlyantman
Nov 11, 2015 12:53 PM
hung861988
Feb 13, 2015 04:45 AM
treager
Aug 27, 2014 11:28 PM
killme4food
11
Oct 20, 2008 10:19 PM
