Block back from machine shop. Need opinions.
Old Mar 7, 2011 | 03:45 PM
LCS's Avatar
LCS
The block just came back from machine shop. They bored it for 86mm pistons. When I was about to install the head I found this:
Is this a big problem? I´m thinking about rounding that and just assembly the engine.
Also, the headgasket is a bit smaller than the cylinders. Looks like it´s limits are 85,5mm pistons. Is there a 86mm specific gasket? It´s an OEM Evo 8 gasket.
Old Mar 9, 2011 | 10:12 AM
boostless's Avatar
That is normal, it's so the rings don't catch when the pistons are being installed.
Old Mar 9, 2011 | 10:18 AM
05blue8's Avatar
I think that AWD has posted something about it being a different gasket...
reactionevo8's Avatar
it is not normal,if anything it will cause the rings to catch....
op,is every cylinder like that?...
Old Mar 9, 2011 | 10:58 AM
LCS's Avatar
LCS
The chamfer is ok. What concerns me is the slot that they machined by mistake only on cyl 2. I really have no idea if that´s a problem or not.
Old Mar 9, 2011 | 11:07 AM
LCS's Avatar
LCS
I searched a lot and only found posts stating that I could use the OEM gasket. But it extends over the cylinders by almost 0,5mm.
Old Mar 9, 2011 | 01:32 PM
LCS's Avatar
LCS
Just an update. Just checked again and the stock gasket has a 86,1mm bore. It does clear the cylinders.
Old Mar 9, 2011 | 03:26 PM
n2oiroc's Avatar
that almost looks like a sleeve. either that or they started to bore it the wrong size and stopped a couple thou down.
ExtremeDSM
Mar 25, 2013 06:15 PM
Spooldyou
46
Mar 10, 2007 01:37 PM
Spooldyou
65
Nov 10, 2006 07:18 PM
