Another Buschur Exhaust Thread..with installation instruction.
Here are the instruction Mr. Buschur sent me through pm when I was in the process of putting on my Buschur 3.0" turbo back exhaust with high flow cat and magnaflow muffler.
"Here are some tips on the exhaust. Take the entire system off the car first. Leave the rubber hangers on the car and slide them off the stock exhaust.
Put the downpipe on first, put it on all the way and tighten it down.
Then slide your highflow cat or offroad pipe on, DO NOT tighten it.
Slide the cat back pipe on, be sure to put the hanger on the pipe BEHIND the rubber hanger. Put the bolt in that hanger and snug it up, then slide the muffler on and put that bolt and hanger on.
Now, center the cat or offroad pipe equally between the two ends and turn the cat back pipe so it is level to the ground. Now tighten the clamps on the cat. Next go to the back of the car and make sure the tip is where you want it, also make sure you have a fingers width between the cat back pipe and rear end. If you don't simply push it over a little and then tighten the hanger down on it tight. Now get your muffler where you want it and tighten that clamp.
It is really easy. If you have trouble getting any of the ends to slide together make sure they aren't dented from shipping, if so just lightly tap the dent out with a hammer. If one of the ends don't look perfectly round do the same thing, go about 4-5 inches down the pipe and either squeeze it back round with a large pair of channel locks or you can tap it with a hammer. It will go together but the connections are very close and snug.
Good luck, enjoy the parts."
Well on to the review...I put that bad boy on and had no problems fitting the exhaust on. Only set back was the stupid stock donut gasket on the 02 housing and part of the heat shield getting in the way of the high flow cat to fit nicely
A 5 minute hack job fixed that. All in all it took me and my friend bout an hr or so to put it on using ramps and jackstands. The exhaust fitted perfectly with minor adjustments and the tip sticks in the midddle and about a good inch or more away from the bumper.
I started her up and it sounded beautiful...slightly louder than the stock exhaust outside, but inside its sound like its stock at idle. Warmed her up and let her rip....it was music to my ears for it wasn't obnoxious or droning. I ripped it through first and my head kicked back like a girl giving vicious head.
Definitely more power at the low end and througout the rpm.
I recommend this exhaust to anyone. Go out and buy one, it's on sale!!!
Buschur quality products and service
A 5 minute hack job fixed that. All in all it took me and my friend bout an hr or so to put it on using ramps and jackstands. The exhaust fitted perfectly with minor adjustments and the tip sticks in the midddle and about a good inch or more away from the bumper. I started her up and it sounded beautiful...slightly louder than the stock exhaust outside, but inside its sound like its stock at idle. Warmed her up and let her rip....it was music to my ears for it wasn't obnoxious or droning. I ripped it through first and my head kicked back like a girl giving vicious head.
Definitely more power at the low end and througout the rpm. I recommend this exhaust to anyone. Go out and buy one, it's on sale!!!
Can you take a picture of where you muffler sits in the bumper because mine use to hang real low and i've raised it up a bit more but I just wanna compare how others sits.
Nice, thanks for the write up I have had the same exhaust for about a month waiting for me to put it on.
What did you use for gaskets at the downpipe connection that meets the o2 housing and the high flow cat?
Originally Posted by BrownPoop
only gasket you use is the stock o2 housing gasket. No gaskets anywhere else.
Originally Posted by atlvalet
the donut gasket WILL NOT work with the Buschur downpipe. Step away from the donut gasket.
Are there any features for vibration isolation? I'm pretty sure this system doesn't have a flex pipe. Does it have anything else? Sprung flanges? I've heard some murmurs about people worrying about excessive stress on the downpipe, or the downpipe on the O2 housing.
If those points are not an issue I'd really like to get the TBE soon, probably for a spring/summer install.
Oh and I have a question for you all ....... have you ever noticed a change in the exhaust sound on rainy days, like after you drive over a puddle or something the exhaust will sound different for about 1 min and then goes back to normal....... Any ideas?
tia.
