epm o2 dump question?help!
Old Mar 18, 2011 | 02:41 PM
dank420's Avatar
I just installed an epm o2 dump on my ix, fits perfect. However when the car is in idle i noticed that exhaust is coming out of the dump tube and even babying it while driveing is louder.I may be wrong but i thought that dump only allowed exhaust to flow threw it when the wastegate opens? I have an oem gasket?. My question is, is it normal for this this to happen or do i have a leak?
Old Mar 18, 2011 | 02:49 PM
raasfaas's Avatar
There you go, you need to get a separated gasket like this one: http://www.maperformance.com/maperfo...og-ss-evo.html
Old Mar 18, 2011 | 03:14 PM
dank420's Avatar
so, my answer is then it is not supossed to allow exhaust gases threw it( while idleing or normal driving)- not full boost)
Old Mar 18, 2011 | 03:48 PM
raasfaas's Avatar
no...because at idle the wg flapper is suppose to be completely shut.
Old Mar 18, 2011 | 06:58 PM
dank420's Avatar
thanks
Old Mar 18, 2011 | 07:08 PM
sharkm87's Avatar
i got this same issue...and i used the map gasket..... i have a new hotside to put on tho.. gonna see how that works out
Old Mar 19, 2011 | 10:31 AM
dank420's Avatar
I don't see tho how the hotside would be an issue.
Old Mar 19, 2011 | 10:37 AM
sharkm87's Avatar
well, i;m not sure the flapper seals properly... when i pushed down on the flapper the amount of air comin out the dump was alot less , but still there...
so i tightned the wg more.. but still yea the amount of air was less, but still leaks... so im guessing flapper in hotside is a little screwy
Old Mar 19, 2011 | 04:26 PM
sparky's Avatar
Just try preloading the WG some more. Shorten the actuator rod by rotating the turnbucle inward a few more turns.
Evolessfornow
23
Jun 3, 2011 10:57 AM
jnut24
Mar 27, 2011 09:03 PM
brandEvO
Aug 18, 2009 10:28 AM
DDATuned
Mar 12, 2009 01:56 PM
importjake00
17
Nov 16, 2008 12:52 PM
