Blitz TT install ?
Old Dec 15, 2003 | 08:53 PM
chronohunter's Avatar
Question Blitz TT install ?
I am trying to install my Blitz TT with the harness. There is a white wire that comes of by itself on the harness and I can't figure out where it goes. I did a search but could not find any reference to the white wire. Everyone says the install is so easy (w/ harness) so I'm feeling kinda' dumb
Old Dec 15, 2003 | 09:17 PM
colateralgees's Avatar
From: West Texas, where the roads are straight and long, and the law is few and far between
I'm getting ready to install a Blitz FATT DC III TT myself, but not until this weekend...just came today. The vendor sent a separate harness made by HKS. It doesn't have any separate single wires. The only single wires on mine are one on the harness that came inside the TT box (this harness connects to the HKS harness and the TT control unit), and a long purple wire that connects to the back of the TT control unit and taps into the handbrake wire in the console.
The single wire that comes off the harness that came inside the TT box is black, and has a "spade" style connector on the end of it. It's a ground wire that you have to connect somewhere to bare metal, on a screw or bolt under the dash some place convenient.
Didn't your TT come with instructions in English?...Which model did you get?
You might get more responses from people that have done the install with the exact same TT as you have if you go to the Evo Tech Forum and post...
Sorry I couldn't be any more help...
Old Dec 15, 2003 | 09:34 PM
Thanks, the white wire comes out of the Blitz harness. It has the three colored wires that are togeather in the connector then this seperate white wire by itself. it comes off the harness not the TT
mojo's Avatar
I just finished installing a Blitz DTT/HKS harness the other day. My harness had two black ground wires (wonder why mine had 2) with spades that just connect to any grounding points. I also had the purple wire that connects to handbrake wire under the center console. Those were the only single wires in the setup. There were definately no single white wires What type of model TT is it?
OH it's a Blitz harness. Must be the ground then?
Old Dec 15, 2003 | 09:43 PM
Who knows? thanks for taking a stab at it. I guess I should have got a HKS harness! Someone must have done this with the Blitz harness (which dosen't have directions BTW). The TT install manual doesn't mention the white wire either, maybe I got the wrong harness?
Old Dec 16, 2003 | 07:21 AM
bump
Old Dec 16, 2003 | 12:28 PM
mojo's Avatar
Chronohunter,
PM Zeus he has the Blitz harness and will be able to answer your question.
Old Dec 16, 2003 | 02:29 PM
Thanks Mojo
Old Dec 16, 2003 | 05:34 PM
my GUESS is the white wire on the Blitz harness is the ground wire...white is sometimes used for grounds...and it apparently requires grounding, or the other harnesses wouldn't have a ground wire
I can't figure out why the HKS harness mojo got has 2 black ground wires and mine only has one....kinda' weird...but the instructions that came with my DCIII model Blitz FATT only show 1...maybe it's a difference between the DCII and DCIII TT's ??
cs82685
May 14, 2007 03:05 PM
Lazeum
10
Apr 15, 2006 10:57 PM
Blue Evo 8
14
Jul 10, 2005 06:22 AM
nubby
Jun 30, 2005 02:57 PM
mertdinc
Apr 23, 2004 09:34 AM
