BLITZ DTT WONT work with keyless system
Old Apr 22, 2004 | 10:46 AM
mertdinc's Avatar
Man i am upset. I have just installed the Blitz DTT and the keyless wont work . I used the original Blitz harness that came with it specific for Evo 8. The nly wire not connected to anywhere is a white wire that is loose on harness. I read through the forum , it says hks harness is needed. What is the difference , I really dont understand why the original won't work....
Old Apr 22, 2004 | 11:06 AM
1QWKEVO's Avatar
Humm sounds like install error.... I didn't even use an Evo harness and it works... Try moving that white wire around in the harness nothing should be loose.
I am running a Blitz FATT which is the same thing only calculates time off ignition not boost... Same wires to install I used a 2G harness becasue nothing else was available when I got my car...
Old Apr 22, 2004 | 11:09 AM
Hanzo's Avatar
I too am using the Blitz DTT but with HKS harness. It works for me, might want to make sure all of the harness plugs are secured.
Old Apr 22, 2004 | 11:13 AM
Zeus's Avatar
Mine is working fine... Blitz harness...
Old Apr 22, 2004 | 12:50 PM
TheBigLubinsky's Avatar
Try HKS harness. Just installed mine. It was a b****, but works great!
Old Apr 22, 2004 | 07:13 PM
mertdinc's Avatar
blitz dtt keyless fix
well i solved the problem
while i was trying to re install the top steering cover i knocked the plastic cover of white thingy right behind the ignition.
Apperently that white box have a relay in it that senses (mechanically) the position of the key and then sets the lights and door ajar beep. When i knocked the plastic cover i did not notice that i also dissassembled the mechanism inside the box which is basically the small metal part and two small coils. I had put the metal part but i havent noticed the coils at first, then while i was troubleshooting today i solved the mystery (bling bling two loose coils on my floor mat??). The genious I am quickly re assembled the box and re installed it. Now everything works perfect.
Moral of the story is
Do not install anything at NIGHT.
Unless you have infrared vision or some sort
Old Apr 23, 2004 | 09:08 AM
Z1 Performance's Avatar
Mert - glad it worked out for you - I knew it had to be something simple, but its so hard to diagnose those things via email, without the car in front of me
Old Apr 23, 2004 | 09:34 AM
Novtec1's Avatar
Veteran: Army
Re: blitz dtt keyless fix
i did the same thing...... don't feel bad but i took mines to the dealer and they put in a new for free..i couldn't find the insides of mines.
grubiaco
Jun 27, 2005 05:47 PM
mrbkkt1
Dec 12, 2004 07:26 PM
NTHECRUX
Jun 21, 2004 11:54 AM
blewbyu
May 26, 2004 01:24 PM
