Why is my stock Evo 5 turbo lag???
Old Mar 21, 2011 | 08:00 AM
jameswwt's Avatar
Hi,
do anyone has any clue why my stock turbo lag?
No boost leak.
My current engine spec's :
85.5mm Piston
GSC S2 cams
Ralliart I/C pipings
600mm x 300mm x 75mm IC
Stock TB & Int Manifold
Banana Manifold with Turbosmart 21psi spring w/g
Profec B II Boost Controller
I recently has adjusted the boost controller and will it effect the map which also caused the lag?
My turbo start boosting at 3700rpm
Old Mar 21, 2011 | 08:42 AM
evonut270's Avatar
remove the turbo elbow and check the the wastegate flap. some double flap wastegates have known to wear and not seat correctly causing the lag you describe.
is it an external W/G your using?
Old Mar 21, 2011 | 08:47 AM
jameswwt's Avatar
Hi Evonut,
yes, im using external wg...Turbosmart 21psi spring.
Old Mar 21, 2011 | 08:54 AM
jameswwt's Avatar
Btw, will a leaking exhaust or exh manifold cause lag?
Old Mar 21, 2011 | 11:18 AM
RSMike's Avatar
does your wastegate feed pipe off the manifold come from both scrolls?
have you had your car properly tuned yet?
Old Mar 21, 2011 | 05:30 PM
jameswwt's Avatar
Hi RSMike,
on the wg feed pipe im not very sure and ive tune my car abt a month ago but the boost still start on abt 3400rpm and after i adjusted the boost controller the start boost comes even later around 3700rpm...
Old Mar 21, 2011 | 06:45 PM
RSMike's Avatar
Originally Posted by jameswwt
Hi RSMike,
go and have a look at your car and see if the pipe comes off both scrolls or just 1 scroll
Old Mar 21, 2011 | 09:02 PM
jameswwt's Avatar
Hi RsMike, i think is 1 scroll..
Can view some pics on "Pls comment on my set-up" thread...
Thanks
Old Mar 21, 2011 | 10:05 PM
RSMike's Avatar
thats looks like your wastegate is coming off both scrolls, and i bet it doesn't have a divider in it.
This will cause 500-700rpm extra lag over a stock wastegate setup.
Old Mar 22, 2011 | 03:21 AM
jameswwt's Avatar
No wonder!!!
Thanks RSMike...
Old Mar 22, 2011 | 03:39 AM
RSMike's Avatar
i hope you didn't weld the internal wastegate shut.
i would take off the external wastegate, weld those pipes closed and run the internal wastegate.
If you do this, MAKE SURE YOU GET IT RETUNED.
the new zones will need to be remapped.
DO NOT BOOST IN THOSE NEW ZONES
Old Mar 22, 2011 | 04:24 AM
jameswwt's Avatar
Mike! You are
And yes, i did weld the internal w/g...
jameswwt
43
May 4, 2011 06:25 AM
jameswwt
Oct 12, 2010 07:11 PM
jameswwt
12
Sep 20, 2010 10:11 AM
Orangeblast
Aug 3, 2010 10:55 AM
DJ Brett B
140
Apr 29, 2009 07:54 PM
