With EXTREME REGRET I post this warning.......
Old Mar 27, 2011 | 03:37 AM
  #106
LGshow19's Avatar
I believe Dave said they will be using "Red Loctite" for future BR 65mm Throttle Bodies.
You should look at the TB anyways just to be safe. Maybe use more Loctite.
Correct me if im wrong Dave, just trying to help out.
Old Mar 27, 2011 | 05:40 AM
  #107
Imhere4you2NV's Avatar
I think i would cry if i ever had that happen...sorry to hear about it
Old Mar 27, 2011 | 12:07 PM
  #108
lillev23's Avatar
this happened to a buddy of mine as well on a stock motor. It destroyed the block, head, pistons, and everything.
Old Mar 27, 2011 | 12:27 PM
  #109
nytalonTSi's Avatar
Wowza. That's terrible, sorry to hear...
Old Mar 27, 2011 | 03:39 PM
  #110
David Buschur's Avatar
We changed the type of Loctite we use to a stronger grade. Of the probably 1,000 EVO throttle bodies we've made this is the first incident.
The car will go back together with our fab'd intake, that will be the main change.
Old Mar 27, 2011 | 03:52 PM
  #111
tscompusa2's Avatar
when i remove my upper pipe from the throttle body and I check to see if the screws are tight and if they are tight should i just leave it as is or do you recommend undoing them and red loctite them? asking for your own professional opinion / advice here. the TB is about a year old.
Old Mar 27, 2011 | 04:30 PM
  #112
gymnasty's Avatar
thanks dave for clearing that out. my question is would the one i just purchased come with this new type of loctite? i bought mine on the 23rd of this month.
Old Mar 27, 2011 | 06:09 PM
  #113
apagan01's Avatar
i am super picky about anything i love safetywire, locktite anything that will keep my system together, reduncancy is your friend,,, thats where the 271 Red comes to play, if i ever want them screws to come out i want them to come out when i tell them to not when they want to, ill use a heat gun to heat up the hardware to soften the loctite and back off the screws beacuse the Red 271 is a permanent L-Tite
Old Mar 27, 2011 | 06:24 PM
  #114
n2oiroc's Avatar
i think i will red loctite them, then take a center punch and peen the ends of the threads over for even more security.
Old Mar 27, 2011 | 08:38 PM
  #115
Evoluvin's Avatar
Sorry to hear. But thanks for the heads up!
Old Mar 28, 2011 | 07:24 AM
  #116
apagan01's Avatar
believe me the red will not come loose at all, we use it in aresopace space and aviation the heat and loads are much more extreme than a 800 WHP car
Old Mar 28, 2011 | 09:33 AM
  #117
ct9asilver's Avatar
Originally Posted by rich1
Wow I am very sorry to hear
Dude your posting everywhere today.
Old Mar 28, 2011 | 11:05 AM
  #118
If you ordered yours last Wednesday then you should be good. All throttle bodies assembled since this happened have been done with Red.
It won't hurt anyone checking theirs to take the screws out and put Red back in place.
I don't want this to happen to someone else but then again I'm not trying to instill panic either.
Old Mar 29, 2011 | 04:38 PM
  #119
dabeast's Avatar
man that hurt to read! im really sorry that had to happen man. best of luck with the new parts.
Old Mar 30, 2011 | 08:05 AM
  #120
joyce1bro's Avatar
cant wait to see the results... I was hell bent on a 2.4ltr Long Rod but this has got me all confused!! Damn you Dave!!!! =)
