Transmission output shafts question
Old Mar 26, 2011 | 05:11 AM
Rob_GPT's Avatar
I've got an '05 with ACD.
How much play is acceptable in the inner "output shaft" of the transmission? There are 2. The outer one is very firmly mounted... my inner has a little play. After inspecting the transfer case it seems that this inner "shaft" would be firmly supported by the TC. Both shafts are really the splined "tubes" that go into the T-case... not the rod that runs through the tranny to the driver side.
Old Mar 26, 2011 | 05:38 AM
Celica2EVO's Avatar
It feels like alot of play when its out of the car. But what you have to remember is once it goes in the car its locked together with the transfer case on the outside of it and also has the 2 shafts running through the inside of it so once its all installed its tight in there.
Old Mar 26, 2011 | 02:46 PM
javicracer's Avatar
if you have play on your imput shaft you should replace the bearing. The play on the center diff is normal
Old Mar 30, 2011 | 04:52 AM
Rob_GPT's Avatar
the input shaft is tight as a drum. The only thing that has play is that inner shaft on the output side into the t-case. Sounds like I'm probably good to go.
Old Mar 30, 2011 | 10:59 AM
javicracer's Avatar
yes the play on the diff is normal.
blowngasket
Apr 13, 2013 10:40 AM
CrunchyMilk
May 21, 2011 07:13 PM
iluvmydsm
May 15, 2011 12:18 AM
snafufx
11
Mar 26, 2011 09:00 PM
wazmunstr
23
Jan 30, 2011 06:23 PM
