Car won't go into gear - Back Again.
Old Apr 5, 2011 | 06:04 PM
playmajohn's Avatar
Okay so I have replaced my entire hydrolic clutch system - clutch slave and clutch master cylinder. completely bled it out with a speed bleeder and there is no air in the line. My car will still not go into gear.
I did a test while the car is off, I put the car in gear and hold the clutch in and someone tries to push it. Before I replaced the master cylinder the car would not roll with the clutch in and car in gear. After I replaced the master cylinder I was able to push the car with the car in gear and clutch in (while the car is off). So I thought I had fixed my problem but when I turned on my car I still get a soggy / pulsating clutch pedal feeling and still not able to get it into gear!
I look through my inspection hole and everything seems fine. The TOB is pulling the pressure plate fingers.
Any other final advice before I actually pull this damn transmission.
BTW thinking about pulling the whole engine with the transmission as last time i did a clutch job I dropped the tranny through the bottom and that was a ***** cause the transfer case is in the way.
Old Apr 5, 2011 | 06:09 PM
wizzo 8's Avatar
This is what I would probably do also. Have you checked to make sure the clutch isnt bleeding down internally? Hold the clutch in and make sure its not slowly releasing.
Old Apr 5, 2011 | 06:10 PM
playmajohn's Avatar
Well im not losing any fluid. I will try it though. Should I have a friend be looking at the slave cylinder to see if it backs off while I'm holding the clutch in?
Old Apr 5, 2011 | 06:14 PM
wizzo 8's Avatar
Yes. Hold it for about a minute to be sure it stays where it was when first applied.
Old Apr 5, 2011 | 06:39 PM
omniprobe's Avatar
Check your clutch/shifter cables.
Z_Lancer_Man
15
Mar 20, 2018 06:00 AM
KillaYayo
May 10, 2017 03:03 PM
hiboost2.0
Mar 23, 2016 05:38 PM
2012evogsr
May 14, 2014 02:17 PM
batmanlee
Lancer Tranny/Drivetrain Tech
Nov 3, 2010 11:17 AM
