Ever wonder what 800ft/lbs of Torque does to a transmission?
Old May 6, 2011 | 05:09 AM
  #211
High_PSI's Avatar
WOW yeah gotta get somethign to keep the entire case from flexing.
Old May 6, 2011 | 09:43 AM
  #212
MikeB@FFTEC's Avatar
ouch
Old May 6, 2011 | 12:18 PM
  #213
InsaneSpeed's Avatar
We started the process of mapping for the CNC case yesterday. I believe this will solve the problem and give us a highly marketable part in the process.
Old May 6, 2011 | 02:31 PM
  #214
03whitegsr's Avatar
Incorporate a rotary shift linkage setup while you are at it to make it fully sequential.
Nice work, that chart is right in line with about the only way in hell I saw this actually being possible. Great spool, although I know the dynapak CAN provide extra load and show 5th gear like spool numbers.
Old May 6, 2011 | 03:53 PM
  #215
3gEclipseTurbo's Avatar
Powers falling off at 7k. So small cams, small intercooler(watercooled?), small piping, close to stock head?
Originally Posted by InsaneSpeed
Thank you sir. Here is the dyno graph.
Old May 6, 2011 | 04:58 PM
  #216
Truthfully it's not a big enough turbo for the motor to take advantage of higher RPM's. We are sucking the turbo dry quickly. GSC Stage 2 cams, full insane speed CNC head, 4 inch IC, and 3 inch IC piping.
Old May 6, 2011 | 05:03 PM
  #217
05-EVO-GSR's Avatar
Winning!!!
Old May 6, 2011 | 05:15 PM
  #218
Specs on the turbo? How much boost?
Old May 6, 2011 | 06:54 PM
  #219
6265 38psi sustained, spiking 42psi.
Old May 6, 2011 | 07:14 PM
  #220
mullen's Avatar
wow is all i can say....very impressive
when is the site going to be fully operational?
Old May 6, 2011 | 07:37 PM
  #221
What hotside?
Old May 6, 2011 | 07:48 PM
  #222
We are working on that. The e-commerce should be up soon, at least for Evo.
Old May 6, 2011 | 08:23 PM
  #223
rdgsdsm's Avatar
wow awesome stuff going on there
Old May 6, 2011 | 08:56 PM
  #224
turbopineapple's Avatar
The ramping rate was the same for the UMS Evo as well as our Evo. Ill try and find out if Ryan Gates Evo was the same ramping also.
mikey
  #225
Guerillah's Avatar
The turbo is obviously maxed out, even then its still making 470ft/lbs at 8000rpm. The cams are on the small side for a build like this. It must feel ridiculous with all that torque.
