Car dies at startup or when clutch is pressed. Need help :(
Old Apr 8, 2011 | 10:09 AM
bonesaw52's Avatar
So far I have checked AEM my engine load is sitting right at 99-100. I havent found any vacuum leaks and currently just stumped on the issue. At startup it will sometimes be fine then start dying after running for 3-5min. or it will just start then die. The process it does this in is 1200 idle drops too 900 too 7-500 then dead. Above 2k rpm I can't hear a problem nor while its driving. but under 1500 it starts bucking on decel and if the clutch is depressed it dies. PLEASE help with any ideas as to whats wrong as I currently have no idea. :/
Old Apr 8, 2011 | 10:16 AM
sharkm87's Avatar
could be the IAC takin a poo
Old Apr 14, 2011 | 10:02 PM
bonesaw52's Avatar
OK, now the car idles around 1250. If i tap the gas 3-40% of the time it will go to 25-3000rpm and stay there. If it doesn't do that it will idle for 30-45 seconds on its own then slump down to 7-800rpm and die. I have no idea what the problem is. I have changed out IAC but not the TPS. But I really have no idea what the problem is. Please if anyone has an idea post up. I'm at a loss here.
Old Apr 15, 2011 | 12:12 PM
bonesaw52's Avatar
anyone?
RUNNING.AMOK
Aug 11, 2017 10:08 AM
jb988
Lancer Engine Tech
20
May 18, 2016 04:53 PM
supak111
Mar 28, 2016 03:29 PM
RSGuy
AEM EMS
17
Jun 6, 2007 08:28 AM
TrinaBabe
AEM EMS
36
Dec 28, 2005 12:37 PM
