Missfire all the time! HELP
Old Apr 16, 2011 | 01:45 PM
n3ro999's Avatar
Hi, my evo 8 missfire very often! I changed ingnition, spark plug, spark, and the problem is not resolved. Also, I have rough idle and small miss at low rpm...
please help me....
Old Apr 16, 2011 | 08:30 PM
ak47po's Avatar
Do you have cams.
Old Apr 17, 2011 | 05:07 AM
n3ro999's Avatar
I'm not sure! hahah
I recently bought this car!
But cam can make missfire?
Old Apr 17, 2011 | 04:02 PM
YogSaahoth's Avatar
Veteran: Army
are you throwing random misfire codes or just popping alot? what plugs are u using and what are they gapped to?
Old Apr 17, 2011 | 04:36 PM
EvilEVO800hp's Avatar
check TP sensor, major imput for your ecu could be throw it off.....scan it, does it look "noisy" ? or have a dead spot?
Old Apr 17, 2011 | 04:42 PM
stck_trbo_mnstr's Avatar
bent vlave
Old Apr 17, 2011 | 05:33 PM
n3ro999's Avatar
I have multiple misfire code.
This is what I put in the car:
Okada plasma coil
Magnecor KV85 cables
BRR8ES sparks
What you mean by check TP sensor?
Old Apr 17, 2011 | 05:37 PM
n3ro999's Avatar
Also I check the compression and everythings is correct! Like new...
Old Apr 17, 2011 | 05:43 PM
casper980's Avatar
Check battery voltage and battery terminals, I had a little misfire when I installed my sparktech... turned out the Cdi wasn't getting enough juice.
Old Apr 17, 2011 | 08:27 PM
have you put a fuel pump in recently?
Old Apr 18, 2011 | 09:23 AM
n3ro999's Avatar
No fuel pump since I bought the car
Old Apr 18, 2011 | 10:02 AM
casper980's Avatar
what spark plug gap are you running?
Old Apr 18, 2011 | 12:51 PM
Serbj's Avatar
I think it's maybe because of ECU capacitor failure?
Old Apr 18, 2011 | 05:26 PM
n3ro999's Avatar
I'll try a tune in a couple of days! I hope.....
Old Apr 21, 2011 | 09:49 AM
bmxer4it's Avatar
Bent Valve or... (dont laugh), you might have a Rocker floating around in your head. This happened to me. Kept getting misfires, yet everything else was working fine! Easy check, take off the valve cover and look for all your rockers. Hope you get it to work.
