Surge Tank Setup...
Old May 21, 2011 | 07:04 AM
silentkiller's Avatar
Anyone...
Old May 21, 2011 | 07:17 AM
n2oiroc's Avatar
Originally Posted by CO_VR4
n2oiroc -- What are you building with those slabs of aluminium -- looks like they are thick enough for suspension parts...?
Its for the surge tank. I bought 1/4" because thats what ams uses on theirs, now that i have the material i would go no thicker than 3/16" next time. The 1/4" is just overkill and kind of heavy.
Old May 21, 2011 | 07:18 AM
n2oiroc's Avatar
I would put the filter after the pump feeding off the surge tank. If the pump goes it will send crap right to the rail and injectors.
Old May 22, 2011 | 05:06 AM
Ok now i would like to discuss about the lines...
I have 1 x 8an outlet & 3 x 6an outlet on the surge tank.
8an - surge tank to fuel rail.
6an - for overflow bck to cell
6an - fpr to surge tank ( run frm below the fpr back?
6an - cell to surge tank
Am i correct?
Old May 22, 2011 | 05:54 AM
240Z TwinTurbo's Avatar
Originally Posted by silentkiller
Is it possible to run just 1fuel filter for a twin external inline setup. Filter run after fuel pump as the twin fuel pump will run into a fuel converter block.
Possible? Any flow issue?
Advise please....
Setup will be in this manner;
2.5L Surge Tank -> 02X EXTERNAL FUEL PUMP -> FUEL CONVERTER BLOCK (2XINLET + 1XOUTLET) -> FUEL FILTER -> LINEs to FUEL RAIL.
I ran a similar setup on my twinturbo 240z. Please see pics below and I would not recommend running the Earl prefilters on your setup.
The filter is a Permacool filter that has 2x 1/2 NPT inlets/outlets and flows 25gpm. I ran each pump to the inlets and used a single -10 outlet.
Old Sep 8, 2013 | 07:33 AM
Thrilla's Avatar
Veteran: Army
Noob question, but is a retune needed after installing a surge tank?
razorlab
Dec 6, 2016 08:45 PM
ryukinevo
Nov 13, 2015 12:00 AM
napolean
Oct 8, 2015 05:02 PM
krisiun
18
Nov 23, 2013 10:13 PM
jessmanEVO
Mar 2, 2012 10:32 PM
