Clutch pedal click
Old Apr 27, 2011 | 06:58 PM
evoid's Avatar
Exclamation Clutch pedal click
I have a strange click feel in my clutch pedal on depression and release about half way through. It is only slightly audible and with no squeak. It could have been there all along and I just started noticing it... is the pedal glide supposed to be completely smooth top to bottom? Thanks! (Is a bit of grease needed?)
Old Apr 27, 2011 | 08:47 PM
savagejay1's Avatar
I have an 8 with stock clutch and its smooth. Not sure if the 9 would be different. Do you have stock clutch or have you ever had any clutch work done?
Old Apr 28, 2011 | 06:20 AM
evoid's Avatar
My drivetrain is almost complete stock.
Old Jul 31, 2011 | 09:39 PM
mmixan's Avatar
i have this exact problem on my IX that i just picked up. did you figure anything out with it?
Old Aug 1, 2011 | 03:03 PM
evoid's Avatar
Actually, it seemed to go away after a little time. It was really small and almost unnoticeable. From my experience with an 08 SE-R, where I had the same kind of problem only worse; take it to a dealer and have them lube it. I just replaced my clutch on my IX and it is pretty smooth all the way through the push. I hope this helps!
Old Aug 2, 2011 | 05:59 AM
mmixan's Avatar
well that's good to hear, not so worried now. heard that answer alot, that its just a stick rod in the master clutch cylinder. planning on taking the car to the dealer this week for other stuff, so i'll add that to the list. thanks!
smoothevo
Mar 22, 2025 01:46 PM
cts4g63
Jan 6, 2016 02:22 PM
bluevilevo8
11
Sep 7, 2015 06:30 AM
mmixan
Feb 14, 2012 12:03 PM
fastevo03
Jan 22, 2009 02:05 PM
