450cc injectors limits???
Old May 7, 2011 | 07:29 PM
kenepo_11's Avatar
want to know the limits of the 450cc injectors....how much whp can they provide
Old May 7, 2011 | 07:47 PM
casper980's Avatar
There are calculators out there for this, using BSFC. Google search: Injector calculator or click here
Old May 7, 2011 | 10:15 PM
awdordie's Avatar
quick question, what kind of vehicle im assuming evolution since this is evolutionm.net if its an evo 8 or 9 y would u have 450cc injectors cuz stock injectors are larger than that.
Old May 7, 2011 | 10:27 PM
Piro Fyre's Avatar
I'm guessing a Talon since it's under his "Drives" sig.
Old May 8, 2011 | 08:11 AM
dastallion951's Avatar
honestly 450cc youll be kinda maxed out on idcs in the 200-350 whp range, stock evo injectors are 550cc iirc, so your best bet try and source some stock evo injectors thatll get you in the 300-400hp range, before you max them out, you need to realize your goals for the car, and work the mods into that goal. If you want 400 hp, you want at least at the minimum 880cc injectors if running pump gas only, 1000cc minimum if you want race gas or e85 depending on your hp goal. Good luck post up anymore questions.
Old May 8, 2011 | 08:52 AM
JohnBradley's Avatar
We normally max 450s out at about 300whp.
aaron
Old Aug 24, 2012 | 12:32 PM
andy2964's Avatar
Do the DSM 450cc injectors require a resistor box or can they be dialed in via ECUflash?
EcHo714
Jun 3, 2015 09:22 AM
babaz7
15
Apr 9, 2013 08:27 PM
steven121
Sep 1, 2012 05:28 PM
ablan029
Apr 25, 2010 04:22 PM
leong
Jan 9, 2010 06:19 AM
