smoke after boost and at idle
Old May 8, 2011 | 06:56 PM
EvoVIII03's Avatar
Ok so I parked my evo for the winter and decided to bu a few things. I purchased a used fp green hta from a member on here, 1000cc injectors, buschur intake pipe and ets fmic. Well I started on a remote tune last week and I started to notice the car smoking at idle a little more than usual. So then I did my first 3rd gear pull and after hitting full boost and decelerating a ton a smoke came pouring out of the exhaust. However I do not get any smoke what so ever when cruising and staying out of boost. Could I have been stiffed when I bought the turbo or could it be something else? Maybe valve stem seals?
PICS BELOW
Old May 8, 2011 | 07:00 PM
FedEvo8's Avatar
What color was the smoke?
Old May 8, 2011 | 07:04 PM
4whlbst's Avatar
Most likely the turbo. Sounds like shaft seals. Pull off the intake and check shaft play.
Old May 8, 2011 | 07:08 PM
EvoVIII03's Avatar
Blue smoke. And I thought it felt like a little too much shaft play when I got the turbo but I called fp and was told thy tend to have a little more shaft play and that it was probably fine. But I know my car didn't smoke when I parked it. That's why I was thinking turbo. Of course I can't get a reply out of the guy I bought it from either.
Old May 8, 2011 | 09:32 PM
4whlbst's Avatar
When I've had a turbo go out, the smoke was prevelant at idle and decel. Did u check movement of the shaft going in and out as well as up and down. There really shouldn't be any movement in and out of the blades. I would suggest pulling it and having it inspected by fp.
Old May 9, 2011 | 04:08 AM
EvoVIII03's Avatar
Yeah there was a very little amount in and out
Old May 9, 2011 | 06:14 AM
EvoVIII03's Avatar
Does anyone else have any input?
Old May 9, 2011 | 06:16 AM
jameswwt's Avatar
I got my gt3076r recently from ATP turbo and my new gt30r too got a little in and out play and ive wrote to atp and they said its normal for ball bearing turbo...
Old May 9, 2011 | 06:20 AM
testa corse's Avatar
sounds like turbo but maybe you should do a compression test as well
Old May 9, 2011 | 08:55 AM
ETS Michael's Avatar
I had a problem similar to this on my 1G. My problem was rings though. It was only on deceleration and lightly at idle. Hopefully it's just a turbo or something that doesn't require you to take apart the motor.
Old May 9, 2011 | 09:57 AM
EvoVIII03's Avatar
The reason I suspected the turbo first was bc my car didn't smoke when I parked it for the winter and now after changing those parts it does
Old May 9, 2011 | 06:13 PM
EvoVIII03's Avatar
I was snipping around and found oil on the band clamp but can't see where it would've came from above anywhere.
Old May 9, 2011 | 06:15 PM
Liqquid's Avatar
I had a turbo do that to me after the seals went out in it.. didn't notice as much on idle but when I let off the gas after doing a pull, light colored smoke and lots of it
Old May 10, 2011 | 03:43 PM
EvoVIII03's Avatar
I did a compression test and it came out 172/163/173/170. I talked to a guy at fp today and he said he thinks I have improper crankcase ventalation.
FoxFMX
Apr 21, 2024 03:42 PM
W0LF
17
Sep 1, 2017 12:40 PM
FoxFMX
Jul 20, 2016 12:12 AM
plan:b
Dec 25, 2015 09:07 AM
Booztd 3
Dec 2, 2010 12:27 PM
