Amsoil Expanded Their SSO Lineup
Old May 9, 2011 | 11:23 AM
Rojo EVO's Avatar
Amsoil Expands Their SSO Lineup
http://www.amsoil.com/InfoCenter.aspx
"AMSOIL 0W-20 (ASM), 5W-30 (ASL) and 10W-30 (ATM) Synthetic Motor Oils join AMSOIL Signature Series 0W-30 to round out the new Signature Series line. Signature Series 0W-30 is now identified by product code AZO. Product code SSO will be discontinued and is only available while supplies last.
In addition to being reformulated to meet the latest API SN Resource Conserving and ILSAC GF-5 industry specifications, the new Signature Series line features all-new packaging and represents the very best motor oils AMSOIL has to offer, allowing motorists to take advantage of maximum extended drain intervals. In the interest of consistency and clarity within the Signature Series line, all four motor oils are recommended for drain intervals of up to 25,000 miles/one year, whichever comes first (15,000 miles/one year in severe service conditions).
The new Signature Series line is replacing the previous formulations of the AMSOIL top-tier oils as inventories dictate; orders will be filled with the older formulations and packaging until inventory is depleted, which may occur at varying times for each viscosity. The former Signature Series 0W-30 formulation (SSO) is available while supplies last."
I'm pretty excited about this and thought I would pass the info along. I currently run the SSO 0W30 and love it, but will probably switch to the SSO 5w30.
Old May 10, 2011 | 02:26 AM
derekb727's Avatar
How often do you change your oil?
Old May 10, 2011 | 07:33 AM
Rojo EVO's Avatar
Every 2,000-3,000 miles.
Old May 10, 2011 | 12:25 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by Rojo EVO
"In the interest of consistency and clarity within the Signature Series line, all four motor oils are recommended for drain intervals of up to 25,000 miles/one year, whichever comes first (15,000 miles/one year in severe service conditions)."
That's crazy! I guess I can save myself some money and stop changing it every 5k.
Old May 10, 2011 | 08:43 PM
SmurfZilla's Avatar
I know the intervals for newer oils is getting longer but I can't shake the old school 3k every oil change.
Old May 11, 2011 | 01:18 AM
derekb727's Avatar
I swear I read somewhere that if you run synthetic and change it less than 5,000 then the oil doesnt have a chance to run its cycle or something. Brand New oil isnt best for a motor.
Old May 11, 2011 | 05:24 AM
Paintballguy's Avatar
You are just wasting your money changing every 3k. I run amsoil in my evo and tacoma. I'll run the tacoma to 10-15k miles, and I run the evo to 5k.
Old May 11, 2011 | 06:40 AM
TommiM's Avatar
Every oil anaylsis I posted on my thread (sticky on this forum) from various evo owners using high quality oil has had no issues going past 3k interval. The only time I will change sooner is when Im running race oil doing track days. DD I keep a little longer. Now not a lot of folks talk about the filtration aspect. If your keeping your oil past 3k I would at least replace the oil filter at that time. my .02
Old May 11, 2011 | 06:48 AM
Danner's Avatar
I usually change my oil due to its age. I could have it in there 6 or 7 months and only put 1500 miles on it. So I usually change my oil per its age not its consistency.
Old May 11, 2011 | 06:08 PM
nudge120's Avatar
Same for me. Is there any issue with running SSO amsoil with their AE filter for a full year and less than 3000 miles?
Old May 11, 2011 | 06:17 PM
rush63's Avatar
Same here!
Old May 11, 2011 | 06:21 PM
kyoo's Avatar
So, Amsoil is gonna have a 5w30 SSO? Considering the first number refers to the cold temp what is the advantage of the 5w30 and 10w30 over the 0w30?
kyoo's Avatar
That's a good point
Old May 11, 2011 | 06:34 PM
project_skyline's Avatar
The only thing to consider when changing it sooner may be if you run e85 daily. Not sure if anyone has done oil testing for over 3k with all e85 miles, or if so to what extent.
Old May 12, 2011 | 06:29 PM
apagan01's Avatar
you already answered your question, it designates the cold start temp.
the trick lays in being able to find the thinnest oil posible that will hold its molecular structure together, if you can use an oil that will keep its molecular structure under heat and shear and or break down by age then you are at an advantage because the engine will spin much looser. and any SSO will do this hands down,,, Group 4 synthetice baby doesn't get any better than that
Fast_Freddie
102
Aug 27, 2019 04:45 PM
BeyondLimitsEvo
17
Jun 5, 2015 03:18 PM
lamakachop
10
Oct 20, 2011 05:37 PM
dambikeracer
34
May 4, 2011 05:13 PM
bouncintiga
12
Nov 28, 2010 01:54 PM
