Tial wastegate/hallman pro mbc
Old May 22, 2011 | 12:11 PM
sleeper04's Avatar
heres my problem i have a tial 38mm wastegate with a bb6262 running a hallman pro mbc. i have put new vacuum lines on it made sure the fittings were tight. But the wastegate will not open, i also have hooked the gate up direct line pressure and it opens fine so i know the gate isnt stuck. Any help would be great havent tried another mbc yet that is my next option.
Old May 22, 2011 | 12:59 PM
justboosted02's Avatar
have you taken the hallman apart?
What spring are you running in the hallman?
What spring are you running in the tial?
Old May 22, 2011 | 01:41 PM
sleeper04's Avatar
stiff spring in the MBC and a big blue spring in the tial, i have had the hallman apart and everything looked fine.
Old May 22, 2011 | 01:50 PM
mt057's Avatar
Post up how you have the vacuum lines.
Old May 22, 2011 | 08:43 PM
sleeper04's Avatar
the bottom of the mbc going to the compressor housing of the turbo-----the side port goin to the tial wastegate (side port and the top port is vented)
Old May 23, 2011 | 06:21 AM
TiALSport's Avatar
that is correct for hookup, what size ID lines are you running?
Old May 23, 2011 | 09:28 AM
sleeper04's Avatar
i have tried 2 different size lines, one that was very hard to get on the tial fittings, and the other that fits alot better but still snug also tried putting clamps on everything. I have tried 3 manual boost controllers and ecu controlled boost all with the same result. im stumped on this one
Old May 23, 2011 | 12:27 PM
browningderek's Avatar
Remove the line from the compressor housing!!! Hook your pressure source to the intake manifold. I have always had weird problems when i use the compressor housing for my pressure source.
plokivos
84
Jun 7, 2017 11:25 AM
galantman03
43
Feb 5, 2017 09:54 PM
evole97
Sep 1, 2015 07:11 PM
kmcconn9
Aug 8, 2007 09:10 AM
MitsuJoe
Nov 19, 2006 04:21 PM
