Review of CBRD BBK Full Turbo vs. FP Green
Synchronic BOV ftw agreed. Thats why my HKS SSQV is sitting in a box in my basement somewhere as well. What fuel/motor are you running for your numbers Aaron?
Well maybe for the extra spool the HKS is worth but it almost always gets outperformed by the BBK. It has yet to put out comparable numbers. Most well setup BBK are putting out 20+ whp on pump and almost double that on e85. More then a few BBK have broken 500whp and none have in the HKS if I recall. Either one makes good power and spools quick. Saying a BBK is laggy is really a relative term because it spools like stock but makes more power than the HKS. To each their own...for that cam/turbo special it was a deal though.
I researched the BBK-Full and HKS GTII quite a bit. In summary, the BBK-Full tends to have a fatter torque/hp curve and more room to grow power-wise. The HKS GTII is smaller and BB, so it tends to spool up earlier and probably faster. Depending on the need, these are two very good turbos. No need to diss one or the other.
This one, the BBK Full. On my car on a Dynojet it should be somewhere around 520whp. Figuring the same power difference of when I took my Green equipped car from Tym Switzer's Dynojet to Pure Tuning's Mustang dyno just 1 hour away - the car should now hit between 515 and 530 on Tym's Dynojet.
I was just making observations based on what is quickly available on Google man didn't mean to sound pompous or HKS bash.
May want to read newer posts on the HKS, there are more then just a few people pushing 400hp on 93.. and several boosting way past 27lbs. As for the comparison-- I have the HKS and its great for me-- mid-range all the way-- no lag. As for the BBK-- thats what I would have purchased if I didn't get a sweet deal on the HKS kit-- plain and simple. Two very good turbos..
Jus Sayin. And even though I recently got my Red back and it's all ready to go I am curious to see how much farther I can go with say... an E-85 tune. But in that same breath I have read on here that people are having howling and other such issues with these but as we all know no turbo is without flaws. Also with my HKS SSQV Recirc BOV I do have that friggin chatter at part throttle but for my first ball bearing experiance I think the GTII awesum for a stock frame turbo! Maybe I will try a 35R next
(Sorry for Hijacking the Thread
Fellas)
Updated original posts a bit.
Just to clarify - I specifically said that for MY needs - I felt the CBRD BBK Full is perfect. YMMV. Maybe you need faster spool and less top end. (I challenge anyone to show a graph of a stock bottom end that makes more than 330ft# @ 3350rpm on a Mustang dyno) Maybe you can give up some spool if you get more top end. That's for each person to decide. All I know is that I am 100% satisfied and I know I made the right choice for me. I am SO thankful that Chad/CBRD wanted to be a part of my racing endeavors this year.
Here are some pics of the turbo right before it went on the car. . .
EVOlutionary is my hero. So, if it works for his application then I would run it as well. This is not some newbie going ecstatic. This guy drives!
The BBK probably has a bit more topend than the HKS 7460. It probably has slightly lower exhaust backpressure and lower EGT's as well.
