Review of CBRD BBK Full Turbo vs. FP Green
I researched the BBK-Full and HKS GTII quite a bit. In summary, the BBK-Full tends to have a fatter torque/hp curve and more room to grow power-wise. The HKS GTII is smaller and BB, so it tends to spool up earlier and probably faster. Depending on the need, these are two very good turbos. No need to diss one or the other.
HKS 7460R + HKS Cams 416/399 on 93 pump ( 1 2 3)
^^ as stated. The HKS and the BBK dyno graphs literally overlay on top of each other.
I've owned the OG Green (same as one in this thread) and the HKS 7460 (currently on the car) The difference between the two is night and day. I think the OG Green is a turd... and probably isn't worth its breath for a comparison against anything except maybe an Evo 8 turbo.
The HKS IMO... is very similar to the BBK, except that the BBK doesn't have surge issues and the BBK has a bigger (more power potential) turbine housing. I made 488 DJ hp with the HKS last year, and I plan to run the HKS versus the BBK when I finish my 2.2L (who knows when that'll happen!)
The HKS surging is something I REALLY dislike...and I'd like it to make over 500... BOTH things the BBK can do. The transient response may not be the same, but I think CBRD is always working to improve previous designs and I'm looking forward to the future developments of BBK lineup.
My 2 cents. I think a good comparison would be the HTA Green, BBK, and the HKS 7460. Maybe I'll have to give it a shot this winter
R/TErnie you read my mind. i want to see both of these turbo's compared to the HTA Green. comparing them to the OG Green is worthless IMO. that turbo is over 6 years old and hasnt been produced in well over 2 years. lets keep the comparisons up to date. and i know your the man that can do it.
and for OP, great write up! maybe too much info lol nah never enough. maybe i missed it, but jw what is your mods?
I am starting to get a little bored already with my power level. Only had the BBK Full on since late March but it is just what I was looking for. Great gains with some room to grow (I'm still on stock clutch, studs, HKS 272s), and while I do feel it is noticeably less responsive than a stock 8 turbo (depsite what most say) it is such a small difference that the extra power is totally worth it. Kelfords, some ported stuff on the intake side, studs, clutch and 28psi are next for me. Hoping to get into the 420s on hp and add quite a bit more torque.
imo this wasn't a very fair comparison of the cbrd bbk against the orginal green. Cbrd is a awsome company from what I see and does great work but how can you compare a turbo that cbrd designed its bbk off of?? Its no secret that they designed there bbk off the green to improve it. Its just not a fiar comparison how about comparing it to the new htagreen not a 7 year old turbo.
I don't think CBRD designed their turbo off the green... that's a pretty slanted comment... nor are the turbos similar in dimension. the HTA Green, BBK, AND the HKS are all very similarly sized. And given that the BBK was the first released out of that bunch...it would behoove us to notice who's following who.
To the OP, great numbers and great write up! I really want to see your numbers around 28-29-30 psi. Should hit 500... Or damn close to it.
Don't both the HKS and FP units have upgraded compressor covers? I know the BBK and BBK-B have the OEM comp cover.
-Jalal
-Jalal
Honestly the response is so good on the BBK-Full that I will probably go to a larger turbo for my 2.3L build. I don't know if the BBK will be breathing enough up top with more displacement and higher boost.
Not really there's been post on here of owners taking the fp turbos there for install and tune and the turbos were physically taken apart and measured and this was all before the bbk turbo was ever released. I'm not knocking cbrd the bbk has proven itself I'm just saying I don't think the op comparison was a legit one. Also the op is comparing the orginal fpgreen to the bbk.
Also this review gives the folks who may be trying to decide between buying a used Green or a new BBK some info and points of reference. For me and for MY NEEDS - I would recommend those folks save their $$ a bit longer and and get the BBK.
