Evo 8 Project - Engine water leak
Old May 24, 2011 | 08:52 AM
rocketguy's Avatar
Recently I bought an EVO 8 that was hit in the front. I thought it would be a quick fix (core support, radiator, twist mounts back.. etc). It turns out that all of the things I assumed were wrong with the car were able to be fixed about as easily as I had thought... but then i found bigger problems.
The issue I'm having with the vehicle now, is that upon filling the car with water to test fire the engine, water started pouring out the side of the motor from behind the timing cover. I was able to see the frost plug on the water pump, so I could determine that wasn't the issue. I've decided to yank the engine out and tear it down. Worst case scenario i'm assuming is if the block is cracked. I have been reading a lot about the 2.4 swap, and also considered grabbing a JDM evo 4 motor as a replacement. If anyone has any ideas on where my leak might be coming from, or the best course of action to fix the engine if the block is cracked please don't hesitate to post!
I'm also looking for a power steering bracket, as mine was cracked and bent from the wreck. The whole mess could be for sale for the right money too.. if someone is interested in a project vehicle.
Old May 24, 2011 | 08:58 AM
rocketguy's Avatar
Here is a picture showing the damage (just after I took the hood off), and another image showing how it looked about an hour before i decided to pull the motor. Should be easy with no core support!!
Attached Thumbnails Evo 8 Project - Engine water leak-2011-05-03-19.34.19.jpg   Evo 8 Project - Engine water leak-2011-05-23-19.25.18.jpg
Old May 24, 2011 | 09:05 AM
rocketguy's Avatar
Here is how it looked when I bought it.. poor little guy is WAY riced out... who spray paints over carbon fiber (on the spoiler)??
Old Jun 28, 2011 | 02:41 PM
Supramane69's Avatar
How much u want for it?
Old Jun 29, 2011 | 05:48 AM
i got the same problem with my evo so when u find out why its leaking plz tell me cause i dont think my head is cracked cause i would know it and mine car runs perfect.....
DrivenFab
Jul 2, 2017 09:03 PM
04ES
Mar 24, 2017 02:50 AM
tbiggs
Lancer Engine Tech
14
Aug 24, 2009 12:02 PM
EVO316
South Region
34
Apr 20, 2006 01:07 AM
