Need some help/advice deciding on turbo and injectors
Old Jun 2, 2011 | 10:33 AM
dastallion951's Avatar
probably james because ur injectors arent scaled right or somethin might be amiss due to the installation....i dont have any experience with sard injectors....maybe u have an injector problem?
Old Jun 2, 2011 | 10:56 AM
DeatschWerks's Avatar
If you are looking at modding as a DD, I'd recommend taking a look at our DW301 pump. I think a W255 would be enough for what you are wanting to do, so the increased flow from our pump wouldn't be much of a selling point.
...but what the DW pump has the Walbro doesn't is quiet operation and a 3-year warranty.
Old Jun 2, 2011 | 01:10 PM
CBRD's Avatar
Originally Posted by GSX_TO_EVO
The beating on will be occasional highway pulls, maybe a drag strip pass every couple months, And i live at US 129 (AKA the dragon, 318 curves in 11 miles) that i frequent often
Can we work out a deal on the BBK Full turbo and the Evo 8/9 intercooler?
Also if i get 1000cc injectors, what kind of fuel control would be needed to control the injectors? 93 octane is available at about every gas station where im at
we always take care of our clients that bundle our product together
cb
Old Jun 2, 2011 | 05:44 PM
jameswwt's Avatar
Should i do a injector cleaning and testing?
Old Jun 2, 2011 | 07:09 PM
GSX_TO_EVO's Avatar
I have decided not to run meth injection, thanks for everyone input, im still undecided on turbo choice though, but i am highly considering the hks 7460r, and ill be running a new OEM headgasket
Someone asked about what cams im going with, im also undecided on them also, which would be the best choice for my setup?
Also no one ever answered the question about tuning the fuel control on 1000cc injectors, what kind of fuel controller would be needed to control these?
Old Jun 2, 2011 | 08:27 PM
stackhouse's Avatar
If you go with the HKS turbo, might as well go with HKS cams too. Otherwise, GSCs S1s or S2s work well.
Im not sure what youre referring to for controlling the injectors. The injectors are controlled by the ecu, and therefore they will need to be dialed into the ecu (proper scaling and latency values). You should be fine on the stock fuel pressure regulator.
Old Jun 2, 2011 | 08:38 PM
tiggeryellow1's Avatar
Veteran: Army
+1... I am running 1000cc Precision Injectors and it's all handled through the tune. I agree if you end up with the GTII the HKS cams should be a good look. Or you may wanna give Kelfords a try. I have used Kelford 272's with the GTII and the FP Red... They're real good cams and not overly loopy at idle.
Old Jun 2, 2011 | 09:22 PM
jameswwt's Avatar
Old Jun 3, 2011 | 08:37 AM
yea if u want james, as far as injector cleaning goes, you dont need to remove them to clean them, they make some fuel induction cleaner, that goes in through one of the big vacuum lines, and sucks into the intake system to remove carbon, id say if that dont help, next step would be havin them removed and sent out to RC to be cleaned and inspected and they give you results for how the injectors sprayed compared to there CC rating.
Personally GSX I wouldnt run the HKS turbo, sure its ball bearing, sure it spools as fast as the stocker, however power wise im not knocking the hta green, but thats about where the power is maybe a little less then that. So personally, your best bet would be an hta green, and fp red, or a bbk b or bbk full... as for cams go with either kelford 272s, or gsc s2s...those cams combined with one of those turbos will make one hell of a fun powerband. You want a broad powerband but no tapering off of power in higher rpms... thats what these turbos will help you with that the stocker and the hks do, there power starts to bleed off in higher rpms on pump gas.
Womb Raider
Nov 4, 2016 07:05 AM
Llew
Aug 19, 2016 09:27 AM
I am me
33
Mar 21, 2015 11:03 PM
scheides
15
Jul 25, 2008 06:39 AM
Megadeth2118
Lancer Aftermarket Forced Induction Tech
229
Apr 8, 2005 12:36 PM
