A/C compressor stays on
Old Jun 4, 2011 | 08:44 PM
Gordian79's Avatar
Im having an issue with A/C compressor staying on.No matter where controls are set to it stays on.The only way to get it to stop is to pull relay out.I did have issues with Aem settings for a/c when i first installed aem ems.A/c lines froze and compressor burst valve open and let the freon out.relay started clicking after that.Is it possible that relay got stuck in active state?
Old Jun 5, 2011 | 09:59 AM
munster87's Avatar
Yea your relay is most likely sticking. I would start by replacing that first.
Old Jun 5, 2011 | 10:53 AM
nightwalker's Avatar
I can't remember if the A/C relay is the same as another in the engine bay. If there is one like it, just swap them and see if the problem moves with the relay.
If not, get your high and low side pressures for the A/C system checked. They can cause that same issue as well.
Old Jun 5, 2011 | 09:12 PM
GearedUp's Avatar
Let me know what you find out on this, I have to get around to doing some testing myself, but maybe this will point me in the right direction. I have the same problem. The only time it's off is when the blower is off which isn't bad this time of year but still needs fixed.
Old Jun 6, 2011 | 09:41 AM
Gordian79's Avatar
I put fog light relay in and ac compressor doesn't stay on.I swapped old one back and compressor stays on.now I think I need freon because compressor doesn't come on at all with new relay.
Helios
Feb 16, 2018 08:35 PM
lghtngyello03
10
Jul 22, 2016 03:26 PM
BTR
AEM EMS
Jun 23, 2016 09:56 AM
Tweak3D
Lancer Troubleshooting
Jul 24, 2009 10:37 PM
ultraflip
41
Jul 22, 2008 06:50 AM
