pro/con on deleting the pcv valve
Old Feb 2, 2012 | 09:53 PM
C6C6CH3vo's Avatar
Originally Posted by Stradag
I would also like to know if this will work. It seems that the suction of the intake will still suck vapors out at idle and it would actually vent more during wot seeing that the old pcv valve port is now open under wot having the intake tube sucking vapors out through both ports.
Input would be appricaited.
That will not work that well but better than nothing. Not enough vac at idle and cruise, just WOT
I just use a catch that has another check valve below. It drains the oil in the catch when off vacuum. Recycles the oil back to earth (street) where it came from - totally green. Never needs eptying
BonsaiScott
Dec 19, 2016 04:26 PM
aamoedo
Oct 28, 2016 09:22 AM
aamoedo
Apr 24, 2013 10:53 AM
DrDeC
Apr 6, 2012 07:19 PM
wannaevo
Aug 18, 2006 02:19 PM
