Turbo boost level problem.
Old Jun 8, 2011 | 06:30 AM
Guru Johnson's Avatar
Hey fellow Evo owners!
Hope everyone is having a good week.
So here is my problem.
I bought a TD05-20G/supposed to be a Evo IX turbo from a Mike Turbo INC and paid to have them upgrade the compressor wheel. I had AWD install it and then dyno it. It wouldn't do more than 24PSI.
They pulled the wastegate control and left it open and I guess it wouldn't even spool to 20PSI.
I read a few things on some other forums and some guys said they had success getting their 20G's to 30PSI using a stronger spring.
I bought the Evo 9 WGA from FP with the 25psi spring in it.
Slapped it in and the most I got was 26.5PSI!
So any thoughts on this?
Oh if it helps .. I have an AEM tru boost EBC. I set the spring to 25.0 and set the duty to 90. The internal sensor is supposed to be good to 29PSI.
I just want to max this thing out and hit 29psi ..
Thanks!
Old Jun 8, 2011 | 01:09 PM
Scsilver2's Avatar
positive there aren't any boost leaks?
Old Jun 8, 2011 | 10:32 PM
Yeah, I had a leak test done twice.
Old Jun 9, 2011 | 06:16 AM
sparky's Avatar
Originally Posted by Guru Johnson
....I set the spring to 25.0....
What steps did you follow to accomplish this? Or, how exactly did you go about setting the spring pressure?
devinfritz
Apr 6, 2015 09:12 PM
Dvolution
Jun 5, 2014 06:24 PM
REVOlution X
36
Oct 16, 2012 08:59 PM
Spec-OpsMotorsports
Evo X Dyno Results
10
May 13, 2012 05:56 PM
Thegame
10
Jul 25, 2007 12:01 PM
