turbo heat endurance???
Old Dec 25, 2003 | 12:28 AM
nonmature's Avatar
ok I have a few questions??? I run the silver state classic which is the worlds fastest road race... I run in the 140 class which has a tech speed of 165...
how well will the turbo hold up at about 150MPH which would be up in the 7K RPM range I'm guessing for an extended period of time... I will be at these speeds for around 36-40 minutes
what would you suggest in order to help with the car for the race...
I am already deciding between a water wetter or purple ice additive to reduce tempertures but I am looking for anything else
-non
Old Dec 25, 2003 | 02:20 AM
ItsStockOfficer's Avatar
You will want a huge ****ing oil cooler and radiator. As long as the turbo is recieving oil at a reasonable temp and your water is in the typical range, you should be fine.
Old Dec 25, 2003 | 09:39 AM
JeffWels's Avatar
you shouldn't have any problems with that much air going through the car.
Old Dec 25, 2003 | 09:42 AM
DynoKing's Avatar
In Timeout
Perfect post. You may want to run it 3-5 min at that speed and see if the cooling can keep up. I am going to say NO, the car is not designed to do that. But we will find out. :-)
Old Dec 26, 2003 | 12:05 AM
nonmature's Avatar
thanks guys lots of help can anyone think of anything besides an oil cooler or radiator(please dont say intercooler obviously that would help too)
-non
Old Dec 26, 2003 | 09:38 AM
Zeus's Avatar
-non
The only reason I mention the Buschur intercooler is that it sits lower than others and is claimed to allow more airflow to the radiator. The thing about it I don't like is the fact that you have to modify the undertray to get it to fit. If your going to change it anyway, this may be your best bet. The larger radiator/oil cooler about covers the rest. That is, unless you want to have your manifold/turbo hot side/O2 housing/downpipe coated... which, of course, will keep a **** load of heat away from the radiator.
bdavis
Nov 22, 2016 07:30 PM
AcePitcher11
20
Oct 9, 2016 11:20 PM
PSUfan1
Jun 3, 2015 10:24 AM
VR4orceCJ
For Sale - Cars For Sale
Jan 17, 2009 07:27 PM
DynoFlash
Jun 26, 2005 04:49 PM
