thrust bearing
Old Jun 11, 2011 | 11:03 AM
Boostedx11's Avatar
thrust bearing
I feel that this is a very stupid question but i cant seem to find any directions for the thrust bearings on the main... i just need the direction of the oil channel and whatnot or a copy of the manual online if possible.
Old Jun 11, 2011 | 12:18 PM
MRfabolous's Avatar
the grooves face the outside of the main itself smooth side which is the back goes inward dont put them in backwards they will heat up from no oil land fall out.
Old Jun 11, 2011 | 12:50 PM
Boostedx11's Avatar
and they just fit right into the main slot? i feel like something else should be holding it in there
Old Jun 11, 2011 | 12:52 PM
mc14's Avatar
Their actually held in by the power of magic
Old Jun 11, 2011 | 01:46 PM
binh's Avatar
I actually had a well known shop build a motor like this for me before...and it ended up in my oil pan in under 500 miles
Old Jun 11, 2011 | 05:45 PM
Boostedx11's Avatar
Originally Posted by binh
I actually had a well known shop build a motor like this for me before...and it ended up in my oil pan in under 500 mikes
Damn!! I guess ill make sure grooves go on the outside!
Old Jun 12, 2011 | 04:43 PM
MRfabolous's Avatar
yes make sure you do that also to make is a little easier you can put the crank in with the mains already in place and then slide the thrust bearings in one at a time in place. you will get the idea when you start to do it. just make sure to be really clean and recheck everything multiple times.
Old Jun 12, 2011 | 04:54 PM
RSMike's Avatar
Or you can installed them with assembly grease. This is what i did. The grease makes them stick to the block so they dont fall out when you put the crank in
Old Jun 12, 2011 | 09:54 PM
Boostedx11's Avatar
rsmike thanks for the idea... i just thought it was weird when i opened the bearing box and had them seperated. I have built several dsms which are all 1 piece bearings
Old Jun 13, 2011 | 12:01 AM
RSMike's Avatar
No worries!
Are you using ACL bearings?
1184H for mains?
Old Jun 13, 2011 | 10:18 PM
Boostedx11's Avatar
Originally Posted by RSMike
No worries!
1184H for mains?
Yes! ive used all acl in the past and knock on wood but it has all worked out well. Clearances are good to go as well
Old Jun 13, 2011 | 10:25 PM
RSMike's Avatar
i found when i used 1184H's for my mains, they were 3.6" for clearance. Too big. I ended up using 1184H +0.025 (1 thou), that closed them up to 2.4-2.6thou!
Good Luck with the build!
A4RON
Apr 26, 2016 02:02 AM
V12KiLLa
10
Aug 11, 2014 10:12 AM
quiquepr69
Jan 16, 2012 07:55 AM
teudmunki9mr
Jun 1, 2009 04:02 PM
mega-z
Jan 12, 2009 10:51 AM
