egr help
egr help
having problems with my egr, egr code came up right after i had my 2.3 built and i replaced the egr valve and it was fine for a while. getting the egr code again tho. anyone ever try removing the egr system altogether or ever use the egr block of plate from bushur?
Yes, read what others have said. You have to disable the EGR Code/s in the P-Bits of the rom. Also you should reach under the intake manifold theres a plug with wires and vac lines just unplug it and remove it and use a block off plate.
Benefits are basically a cleaner intake manifold. Unless it's broken and leaking, it should have no effect on WOT operation, and potentially a reduction in fuel milage, although I didn't notice any.
