question on tps sensor..
Old Jun 23, 2011 | 05:10 PM
DREVO978's Avatar
Question question on tps sensor..
wats up everyone.. so i have an issue.. my car is throwing a P0121 code for the tps sensor.. it says switch A/ low voltage.. now wen i connect to my evoscan it reads 9.1.. is the tps supose to read 13. without stepping on the throttle.. and would it throw a code from being a bit of scaling.. or is it just a bad tps.. thanks..
Old Jun 23, 2011 | 06:59 PM
THUB's Avatar
13% tps is normal when you're off the gas.
Old Jul 20, 2011 | 09:03 PM
eddieededy's Avatar
I had a bad TPS on my VIII and my Voltage was 0.25V at ideling (very weak) RPM was fluxing btw 400~2000 rpm!
replaced it $$$, cleared the code and everything was back to normal.
apperantly some throttol body cleaner must have got into the TPS when i was cleaning the throttol body, (that is a no no)
kamote2000
Sep 30, 2016 10:50 PM
duranvw
Sep 18, 2016 09:27 AM
MrSquirr3l
Oct 3, 2015 03:38 PM
DREVO978
Apr 22, 2012 04:21 PM
yellowevo82
Aug 30, 2009 02:31 PM
