6 Speed transmission rebuild kit?
Old Jun 28, 2011 | 07:48 PM
jxs1984's Avatar
My 80k miles transmission grinds in 2nd gear and 3rd at high rpm when fully warmed up. Shifting at low rpm feels notchy. However on cold start it shifts fine. I have tried adjusting the clutch rod and it somewhat feels a little bit better. I also swapped the fluid with Castrol SynTorq and it feels better on cold start. I only get problems when its fully heated up.
I need to know if its my syncro starting to go or can I solve this with a thicker transmission fluid?
Old Jun 28, 2011 | 08:36 PM
Tuxevo's Avatar
You're already using the right fluid. It might be time to take advantage of the shep rebuild.
Old Jun 28, 2011 | 08:51 PM
fugiwara's Avatar
good time to get the new 6 speed from shep
Old Jul 31, 2011 | 04:20 AM
Dmav1989's Avatar
How much is the shep rebuild kit?
Old Jul 31, 2011 | 05:49 AM
Boostfiend's Avatar
$1900 for the gears + $800 for the rebuild. If you need forks or anything else it may cost a little extra. No transmission is the same so I would set aside at least 3.5-$4k just in case you need a bell-housing or something.
Old Jul 31, 2011 | 09:46 AM
JDM EVO PANAMA's Avatar
I rebuilt mines and changed 2nd and 3rd gear synchro. Along with the slider and shift fork.
Old Jul 31, 2011 | 10:02 AM
dinoz1980's Avatar
what is this new 6 speed from shep that everyone is always talking about ive on there site there is nothing about a 6 speed rebuild
Old Jul 31, 2011 | 10:09 AM
Boostfiend's Avatar
Send an e-mail and ask. It exists.
Old Aug 4, 2011 | 09:26 PM
dinoz1980's Avatar
Boostfiend i have, a few weeks ago, got no reply, ill try again, but if you dont mind how much power are you running with that tranny
Simmons
Nov 2, 2013 08:46 AM
nawaz
36
Dec 28, 2009 09:06 AM
Solo II Evo
Apr 22, 2009 03:08 PM
desperado-c
Mitsubishi TC-SST Discussion
18
Aug 11, 2008 09:48 AM
osunick
30
Apr 2, 2008 02:40 PM
