Best Cams/Stock Frame Turbo for a 2.0LR Build
Old Jul 6, 2011 | 05:33 PM
Tuxevo's Avatar
If you're of a mind to try a 2.2 you might ponder a LR2.4 as you'll be switching your block at that point anyway. On a larger turbo you'll experience a diminished return as the head reaches the limit of how much air it can deliver in the high rpm range, but it's the best of both worlds on the turbo you've got in mind.
Old Jul 6, 2011 | 07:07 PM
Mikey@Spec-Ops's Avatar
S2s or 4Rs.
Mikey
Old Jul 6, 2011 | 07:20 PM
Renxo's Avatar
I will not change block, if i go 2.2 way it would be a 4G63 2.2 (:
Old Jul 6, 2011 | 07:36 PM
I love my LR2.4. Would do anything else honestly. just my opinion. also moving the wrist pin up 9mm will make the piston weaker... I know of two that didn't survive. if you kept the oil squirters it may work just fine. the HD 1400s may be okay with out squirters. I'm thinking about doing a 159mm rod 2.4 with these piston and hope they don't fail.
Mikey
louiesevox
10
Oct 29, 2017 06:56 AM
R/TErnie
26
Sep 23, 2017 04:42 PM
Srt4...
Sep 28, 2014 06:00 PM
RjRacing05
Jun 3, 2013 02:21 PM
TURBO_S2K
23
Oct 25, 2012 01:39 PM
