ACD error codes please help!
Old Jul 12, 2011 | 05:52 PM
xexitenglishx's Avatar
My 3 acd lights have been going on every time i drive my car. They don't come on right away though sometimes they come on after a few minutes and sometimes they come on after 10 or 15 minutes of driving. The fluid was at the lower level of the full level so i topped it off with AFT but that still didn't help.
I pulled the codes and got 65 and 82.
65 is abs monitor system open or short circuit
82 is electric pump.
Does anyone know what to check for the code 65? What parts of the abs monitor system should i check.
Any help would be great....
Old Jul 13, 2011 | 08:58 AM
anyone?
Old Jul 13, 2011 | 08:44 PM
Jersey Dino's Avatar
there is a decent amount of information on this if you search a bit. But a couple things that could be going on are the following. All the ABS sensors are hooked up to that system, so if one is faulty or disconnected or there is a short in the wire it would throw a code. You can effectively test your ABS by jamming the brakes in a safe location and safe speed and see if you lock up the wheels. Check all abs connectors, I forget where the rears are, but the fronts are tucked up in the fender liners. Just follow the sensor from the brakes up.
The electrical pump failure most likely refers to your ACD pumping crapping out. if the pump is failing, it will throw all three lights once the fluid heats up and the pump tries to pump the fluid. The pump is very expensive from the dealer so confirm that it is dead and search for a used one on the forums. good luck
tauro91
Jun 29, 2017 02:14 PM
superkizuna
Oct 18, 2016 03:13 PM
D-Man
Jun 5, 2016 07:53 AM
Steven Silva
Sep 16, 2015 08:18 AM
HaVoC187
May 15, 2011 02:13 AM
