Supertech dual valve spring users, please answer some questions.
Old Jul 13, 2011 | 07:32 AM
devildevil's Avatar
I put this is the advanced section as well but i'm in need of some insight quickly so i'm posting it here too.
I just got my head back from the machine shop a few days ago, where i had supertech dual valve springs installed, to run with HKS 280's. Now that it's to the point of timing the engine, I am curious how hard it will be to hand crank the motor to double check that timing is set correctly? How much of a fight do those supertech duals put up? Anything you can easily compare it to or use as an example of expected tension? My concern is, once i start to crank, if i feel hesitation, is it interference or just those strong springs?
yes i will be doing it with the plugs out.
I know there was a big difference in my wrx with brain crower singles that made getting the cam to its set place a tad more interesting and those only had a seat pressure of 60 lbs where as my supertech duals have a seat pressure of 96 lbs. All speedy informative responses will be greatly appreciated guys/gals. Hoping to finally have everything buttoned up and get to go enjoy the 6262 setup after tuning! Thanks for the help!!!!
Old Jul 13, 2011 | 08:57 AM
Kracka's Avatar
It'll be fine, just use a big 1/2" ratchet.
Old Jul 13, 2011 | 10:55 AM
Teal2nnr's Avatar
^^x2
Sheasta
Oct 21, 2015 03:28 PM
Creatre
For Sale - Cars For Sale
Oct 4, 2015 05:13 PM
Rex915
Jun 12, 2011 05:38 PM
suprafabs
Mar 11, 2010 09:28 AM
Boost3dxEvO
48
Aug 16, 2008 07:57 PM
