Stock Evo 9 Turbo Pressure
Old Jul 19, 2011 | 12:21 AM
hatakashi's Avatar
I'm only "THISSSSSS" close from purchasing an 2005 Evo 9 GSR. This specific car, according to the Defi gauge, runs at 1.7 bar overboost and holds at 1.4 bar. I vaguly remember the owner said he has flashed? the ECU but with no mechanical alteration.
Is it a normal boost pressure for Evo 9 stock?
Old Jul 19, 2011 | 07:57 AM
black_beauty's Avatar
No, it has been turned up in some way... MBC, EMS, somethin. Can it hold it, yes prob, did it from Mitsu, No.
Old Jul 19, 2011 | 02:19 PM
Boostd4's Avatar
1.4bar is roughly 20psi...so that sounds like it's pretty close to stock. Depending on which gauge you're using, they can be off by a few psi/bar.
https://www.evolutionm.net/forums/ev...oking-evo.html
Old Jul 19, 2011 | 02:29 PM
BigT's Avatar
I think you two need to reread his post. He said that the owner said that its already flashed.
So, to answer your question, yes this amount of boost can be had by altering the ECU.
Old Jul 19, 2011 | 03:25 PM
hatakashi's Avatar
Thanks for your link mate, I see that....
"How much boost is my car running stock?It depends on the year:
03-04s run 19.5psi at 3500rpm, which tapers to 16psi by 6500rpm
05-06s run 20.3psi at 3500rpm, which tapers to 17psi by 6500rpm"
So I guess my 05 Evo 9 runs at 20psi is pretty much stock (at least mechanical wise) thanks!
Wanchai Panpron
Lancer Engine Tech
Nov 24, 2016 11:34 PM
prandelli
Mar 24, 2016 12:17 PM
jameswwt
Aug 1, 2015 03:32 AM
mrfred
Aug 14, 2009 07:17 PM
exacc
Apr 21, 2008 09:34 AM
