Mbc vs ebc
Old Jul 21, 2011 | 08:35 AM
pinoy6969's Avatar
Mbc vs ebc
Which is better to have...becuase i was thinking of gettng a ebs aem thruboost..
Old Jul 21, 2011 | 08:41 AM
06MREvo's Avatar
hahah...use the search function!! Over the past month or so there are a couple threads with debating this...
Old Jul 21, 2011 | 08:49 AM
pinoy6969's Avatar
I did...doesnt show that much....just talks about 1 of eac of them...not comparing them..also they dont have good enough data
Old Jul 21, 2011 | 08:51 AM
mt057's Avatar
It comes down to personal preference. Some don't use the ebc because it is another electrical part to "fail". So instead they use a mbc which can not have electrical gremlins. The part failing could cause a overboost or no boost situation.
I personally love my ebc. It is easy to adjust boost on the fly. I also use it to work in conjunction with my HFS-3 to drop boost in case of a flow error,etc.
The only time I have had trouble is when I was changing out my shifter I did not notice a wire was being rubbed by some trim and cause a fray over time. This caused me to over boost. I blew up a spark plug and got lucky. I did not have any issues for over 4yrs before that. It was an install error that caused the fray and my scare.
Old Jul 21, 2011 | 09:01 AM
n2oiroc's Avatar
i prefer manual. no oscillating, easy temp compensation and guaranteed fastest spool with no spikes.
Old Jul 21, 2011 | 09:03 AM
Paintballguy's Avatar
I don't understand how a mbc, which is basically a controlled boost leak, is the fastest spool when you can run a 3 port ebcs in interrupt mode which diverts all air away from the wastegate.
Ecu controlled boost with a 3 port > mbc
Old Jul 21, 2011 | 09:08 AM
n2oiroc's Avatar
im not talking about a crappy bleeder style.
Old Jul 21, 2011 | 09:20 AM
Gary@MellonRacing's Avatar
im on the mbc and happy with it =)
Old Jul 21, 2011 | 09:33 AM
tscompusa2's Avatar
both have their advantages and disadvantages ill leave it at that.
Old Jul 21, 2011 | 09:34 AM
tscompusa2's Avatar
actually there's no boost correction for temps on a mbc unless you manually adjust it.. where as on a 3 port you can control boost based on temps via MAF IAT table automatically when the bec system is setup properly.
Old Jul 21, 2011 | 09:38 AM
Sharkbite2000's Avatar
I loved the AEM to control boost you set it and bam it's there and holding all way through.
Old Jul 21, 2011 | 09:42 AM
tscompusa2's Avatar
actually the aem has a taper just like the mbc's do.. but aem is definitely one of the better ones for sure. i did direct comparisons with aem vs ecu boost and aem killed it with its natural boost taper curve. (i could clone that curve with the ecu boost though) aem uses a mac valve also.
Old Jul 21, 2011 | 09:58 AM
After I went AEM control I never used anything else even when I had a boost leak the AEM kept the boost where it was set I was amazed
Old Jul 21, 2011 | 10:04 AM
tscompusa2's Avatar
it definitely has my vote.
Old Jul 21, 2011 | 10:38 AM
n2oiroc's Avatar
What aboot aem and other standalones? I fought that for months. On a cold morning i can turn the mbc half a turn. Standalone i would need a laptop.
