AC Stalling/Car wont turn over
Old Jul 26, 2011 | 02:29 PM
Evo_IX_Guy's Avatar
Last year I moved from Hawaii to Pennsylvania, during the summer last year (2010) my car turned off completely 3 different times during the summer. I didn’t know what made that happen but I figured I must of stalled out. So I went on winter came and went with no problems besides cold weather. Summer 2011 came and so did the stall issues. I noticed it had something to do with the AC being turned on, it would happen randomly but more often than last year. I figured it has something to do with my tune so I decided to schedule a tune, which is this weekend.
Anyway about 3 weeks ago, I decided to get my clutch installed since I have a dyno/tune coming up. After the clutch install I’ve noticed the AC stall issue happens all the time now. When I have the AC on and I come to a stop, slow down, or turn I push in the clutch and the rpm’s drop rapidly making the car stall. Now my question is, will a tune fix this issue?
Also since the clutch install I’ve been having random ignition issues. My car doesn’t want to start at times. I turn the key, my gauges and stereo gets power but no start. It doesn’t even try to crank. My voltages read between 14.1 & 14.5 but sometimes I seen it drop as low as 13.5. I didn’t remove my plugs but I check to see if they were tight. I cleaned my terminals, and did the alternator test by removing the ground while the car is on and it remained on. So my question is, does this issue have anything to do with the clutch install? Or could it just be my battery? Mini Battery BTW.
Thanks in advance for any help you guys could provide.
MODS
Kelfords 272
Supertech springs & retainers
AMS TBE w/ high flow cat
ACT HDSS w/ prolite flywheel
Buschur air intake
Synapse bov recirculated
walbro fuel pump
Nisei UICP/LICP piping
Nisei intercooler
Arp head studs
Aem tru boost gauge
Aem uego wideband
Mini Battery
Additional info, If it matters I was tuned while in Hawaii in 2009
Old Jul 26, 2011 | 03:17 PM
cfdfireman1's Avatar
prolite flywheel
Old Jul 26, 2011 | 03:30 PM
Evo_IX_Guy's Avatar
Originally Posted by cfdfireman1
prolite flywheel
What do you mean? The flywheel is the cause of my problems?
Old Jul 26, 2011 | 06:01 PM
Could be the cause of the idle problem yes.
Old Jul 26, 2011 | 06:18 PM
sktng22's Avatar
do you have a boost guage? look at the vacuum next time. sounds like the car cant produce enough vaccuum with the ac on with the cams. i had the same problem with my kelfords and exedy triple. you just need to turn up the idle on the throttle body
Old Jul 26, 2011 | 06:19 PM
sktng22's Avatar
and yes when you goto get a tune they will fix this problem for you and your car will run fine with the ac on
Old Jul 26, 2011 | 06:38 PM
Evo_IX_Guy's Avatar
Thanks for the input guys.
Cfdfireman1, I really hope your wrong because that sounds like it's gonna be *****/expensive to fix. Lol.
Sktng22, yea I do have a boost gauge. The vacuum is about 10 with no ac on and 6-7 with it on. I guess with I take it to Ivey this weekend he could take care of that. Now I'm worried about the starting issue I really hope it isn't the flywheel.
Old Jul 26, 2011 | 07:23 PM
Not expensive to fix it just changes engine dynamics, the tuner should be able to fix it. There is a reason that you have a flywheel other than something to attach a clutch to.
Old Jul 26, 2011 | 08:15 PM
VRSF Tiago's Avatar
This can be adjusted via the tune
Old Jul 26, 2011 | 10:21 PM
EVO8emUp's Avatar
When your car doesn't start, can you hear the starter pinion engage? It makes a click sound.
Stalling with the A/C on can also be a result of the ISC plunger or BISS being fouled (covered with carbon deposits).
I would remove both and make sure they're clean before the re-flash. Search on how to set the BISS.
Like mentioned above, the flywheel can cause this because of the decreased rotational mass. However, I would make sure your ISC and BISS are clean before making any adjustments.
Old Jul 27, 2011 | 01:11 AM
ChanseEvo8's Avatar
Registered User
i have the same problem after installing my cams, i usually just turn off the ac before i come to complete stop. Then turn it back on when i am in motion haha.
Old Jul 27, 2011 | 03:55 PM
Evo_IX_Guy's Avatar
Ok thanks that makes me feel alot better. I thought it involved dropping the tranny.
No I dont hear nothing when I turn the key, like the battery is dead but I get power. I dont know what or where the ISC Plunger and the BISS is located but I will do a search now. Thanks.
lol, I was doing the same thing and not only did it became annoying but there were times where I would forget while making a turn and I'll have to become the hulk just to avoid an accident.
Old Jul 27, 2011 | 08:58 PM
sktng22's Avatar
goto peteyturbo hell fix itt
Old Jul 27, 2011 | 09:12 PM
blackmamba23's Avatar
Just had a new clutch put in by Spec-Ops motorsports down here in Fayettnam and I was experiencing this as well. They retuned the car and adjusted the biss screw.Guess this is a common problem the owner said alot of times the biss screw needs to be adjusted after going to big cams. Now my AC runs perfect idles around 1K with it off and 1100 with the AC on.
Old Jul 27, 2011 | 09:52 PM
sktng22's Avatar
like i said.. turn up idle. when you go get a tune theyll do it for you otherwise you can do it yourself with a screwdriver
