Good luck man, and if you lose, ask him to race you on some twisty roads and see who comes superior!
you must remember he is in the ukraine and his evo is actually the 300hp non-US evo so he will win it hands down
squeeze my friend squeeze....
haha I dont know I think with your mods you will win but it will be VERY close... I say install the bottle for an extra 50-75 hp and just use it if you need it... I dont think any evo will have to use nitrous on many street cars but hey why not carry it to make the jaws drop...
-non
-non
why if used responibly it is a great add on to damn near any car... also I've used in it every car I've owned with no problems... (silverado, 2000 honda prelude, and nissan 350z)
-non
-non
You guys keep saying that the M3 will walk away from him on the big end, some said it tops out at 155mph. I thought the EVO ran up too 161mph before it was electronicaly shut down, or am I wrong? I know that the bigger motor will pull harder on the big end but if he has enough room the evo should start catching back up with the 6mph difference on top end. am I way off base here?
John
John
Your evo should beat the M3. There is no esl on mine... my top end is what i get at 7200 rpm which is around 265kmph ~ 165mph...
Ask someone to tune your car so your 10% of maximum power comes around 4500 RPM and peaks at 6500... your top end pulling power will be ridiculous and your torque should maintain within 30% of peak before you reach 7200... however, the sequential shifter of the M3 is fast, so you will have to learn how to shift fast....
one word of caution... its bad for your transmission and your centre differential....
Good luck... if you have around 250-280whp between 4500 and 6500, you should smoke the M3 all the way to 7000 rpm in top gear....
Quote:
Originally posted by vulcan
...Yaros:
You *can* beat the M3 by simply outperforming his current power-to-weight ratio. In other words, if you bring your flywheel power close to 340-350, and (at least) a flat top-end HP curve, you *will* certainly beat him because you are 200-250 pounds lighter (car-to-car).
Vulcan
At the top end, power to weight ratio isn't nearly as important as aerodynamics. The E46 has the Evo OWNT in that department. Originally posted by vulcan
...Yaros:
Vulcan
I say race him up to 120 mph.
Have confidence in your car... its an evo.. if you took good care of it.. it'll take good care of you...
B&B TurboBack(without any cats), Ralliart flat intake, Clutch master stage 3,EBC AVC-R, HKS BOV,HKS IC piping
Hey Slav, here's a tip... put ice cubes and 50% methanol with the water into your intercooler water spray container
and set it on auto... spray your intercooler a couple of times before you launch....
and set it on auto... spray your intercooler a couple of times before you launch....Evolving Member
Learning how to drive your car will help a lot.
A stock evo can and will run 13.1 if launched right.
http://www.CarPhoto.net
Guys , i raced with him, and after 150 he tarted to lose me very slowly. So... I ****ed him! After some tuning i`ll be first!
Thanks!
Thanks!
uh okay!
