Flywheel bolt size
Flywheel bolt size
I'm trying to remove my flywheel. From the Evomoto website it says its a 17mm, but the socket is too big for the bolt, so when I'm trying to remove the bolt it doesn't grip it too well.
Could anyone help me with this? I don't want to round the bolts.
thanks
thanks
Another idea is unless you're using a Snap-On or MAC socket as they will work, grind down the end of the socket flush with the points as there's not much room the grab the flywheel bolts as they're countersunk into the flywheel. I've ruined/rounded off a lot of flywheel bolts before doing this.
Yea, I'm removing the flywheels bolts.
I'm using my IR impact 17mm socket with my IR gun, its not grabbing anything. I'm gonna try buying a new socket though. I've had this socket set for a while so it might be beat up a bit.
Mr. Evo IX
Jul 28, 2016 09:56 AM
MitsuJoe
468
Feb 20, 2016 11:17 AM
Phoenix*
10
Dec 22, 2011 12:31 AM
