turbo suggestion
Old Aug 9, 2011 | 04:39 PM
RoryMarckese's Avatar
turbo suggestion
ok I have come to discover that my turbo on my evo is shot. Looking to swap out....what would be a good turbo to go with that is similar in configuration but with a little more bite. Im not lookin for anything intense. just a replacement for a stock setup. my budget is 800
Old Aug 9, 2011 | 04:55 PM
kanyonkid's Avatar
hta green, good for 500whp on e85. 400hp on pump
Old Aug 9, 2011 | 05:01 PM
sphynx's Avatar
A other option rebuild your turbo with your spec ... When i look my turbo is blow i repair with a 20g wheel for more cfm
Old Aug 9, 2011 | 06:00 PM
where would i send it for rebuild?
Old Aug 9, 2011 | 06:07 PM
FedEvo8's Avatar
You can send it to FP for a rebuild upgrade. Another good turbo upgrade would be the HKS GTII 7460R.
Old Aug 9, 2011 | 09:55 PM
sparky's Avatar
These were my first two ideas as well. Send it in to Forced Performance and have your existing turbo upgraded to an HTA Green. The 7460R would be over the OP's budget of $800.00 however. Or, he could send it in to CBRD for an upgrade to BBK specs.
Old Aug 11, 2011 | 10:34 AM
how much u think it will run me for a rebuild to some of those specs?
Old Aug 11, 2011 | 11:48 AM
mt057's Avatar
It depends on how blown it is. If you have destroyed the exhaust housing it will be more than the basic rebuild. I would recommend looking on both CBRD's, MAP's, and FP's websites to get an idea of basic rebuild cost.
Old Aug 12, 2011 | 08:03 AM
CBRD's Avatar
let me know if we can help-
cheers
CB
Old Aug 12, 2011 | 08:50 AM
ChrisCarey's Avatar
Send us your IX turbo and we'll get you back on the road for $649.99 assuming the housings are reusable
http://turbos.maperformance.com/evo-turbos.html
EF1 Upgrade $649.99
This upgrade service includes an upgraded compressor wheel, all applicable machine work, precision assembly and VSR balancing.
Old Aug 12, 2011 | 10:41 AM
Craig King's Avatar
EF1 Upgrade $649.99
Are there any upgrades you can do to an Evo VIII turbo?
Old Aug 12, 2011 | 12:44 PM
I will give one of you guys a PM once I get done with my DSM
Old Aug 12, 2011 | 12:45 PM
would an evo IX turbo fit on a GST?
Old Aug 15, 2011 | 08:24 AM
ChrisCarey's Avatar
The same upgrade can be done, the comp housing is just a bit smaller so performance may be adversely affected somewhat.
Not without some serious changes to the rest of the exhaust components (manifold, downpipe, etc)
