Blew ignition coil fuse with non COP kit
Old Aug 13, 2011 | 01:23 PM
Firebat's Avatar
Hi everyone. I have a spoolinup kit installed for couple weeks now. Other day I turned the car off. Then got back in and would not start. I found I blew the factory 10amp igntion coil fuse.
I read a couple other posts that some people due to have this problem with non cop kits regardless of vendor. Is going to a 15amp fuse usually the norm to take care of this. I even saw one post Buschur mentioned running a 30amp which I am not comfortable with.
Just trying to get some feedback and see if this happened to others and their fix.
I spoke to Matt who was very helpful and said that should be fine running a 15a but to not go higher.
I just dont want to have to be worried about if the car is going to start every time I get in.
thanks
Old Aug 13, 2011 | 08:01 PM
KentStateTsi's Avatar
Veteran: Army
I have had the same problem man. I keep a spare pack of fuses in the car and change them frequently. I put 2 more grounds from the engine to chassis and it helps a little bit.
Old Aug 13, 2011 | 09:56 PM
06RedRalli's Avatar
Which ignition coil fuse are you referring to?
#1 Under the dash?
Because this happened to me as well about 3 weeks of having my COP kit, and I replaced it with a 20 amp fuse...and haven't had any issues at the moment...going on about 3 weeks of replacing the fuse...
Old Aug 13, 2011 | 09:59 PM
Firebat's Avatar
Yeah it was the under dash one, had a 10amp from the factory. Lasted bout 2-3 weeks
Old Aug 13, 2011 | 10:00 PM
06RedRalli's Avatar
Odd...I was wondering if I was the only one that had experienced this...wondering now how many others have delt with this dilemma...
Old Aug 13, 2011 | 11:22 PM
andrewzaragoza's Avatar
I Have spoolinup for abt a yr now. Never had this happen to me.but i have a couple of custom grounding so that might be helping.
Old Aug 14, 2011 | 12:10 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
So this is normal with the SpoolinUp kit? Interesting.
I hope the instructions tell you to upgrade your fuse.
Old Aug 14, 2011 | 07:55 AM
pls1968's Avatar
I've had mine going on two years and have never blown a fuse so it's not normal.
Old Aug 14, 2011 | 08:18 AM
nytalonTSi's Avatar
Fuses blow, as long as it doesn't keep blowing. Think about it factory uses a 10amp for the ignition but you also only have 2 coils. You add 2 more coils and have a stronger spark. While some get away with not having to replace the fuse others blew the fuse just driving around the block after adding a cop kit.
First thing I did after switching to a cop was replace the 10amp with a 15amp. You might be able to get away with just using a new 10 amp fuse.
Old Aug 14, 2011 | 02:57 PM
sho669's Avatar
The sparktech non cdi comes with a 15A fuse and the instructions tell you to replace it, you are adding a little more load on the ckt as stated earlier.
Old Aug 14, 2011 | 03:00 PM
Firebat's Avatar
Ok thanks guys. I'll swap out to a 15a when I get some time.
Old Aug 14, 2011 | 04:25 PM
Blue Evo 8's Avatar
I found this thread to be very informative, thanks guys!
Is there any advantage or downsides for choosing a 20A fuse over a 15A fuse?
Old Aug 14, 2011 | 04:38 PM
BoostIsMyDrug's Avatar
Interesting thread. I also have a SpoolinUp COP kit. I've had it for about 6 months, with no additional grounding. Stock 10a fuse is holding strong. Subscribed to see if others post with similar problems.
Old Aug 14, 2011 | 11:10 PM
Firebat's Avatar
Well it definitly does make since needing higher fuse rating with the non cdi kit.
Old Aug 15, 2011 | 06:22 PM
SpoolinUp's Avatar
Silver Sponsor
This is exactly right! Doesn't matter on vendor here. 4 coils draws more than 2. Easy math and no it is not a common problem. I recommend a 15a fuse with my system only with the AEM. It seems the AEM puts more stress on the coils for whatever reason. Very rarely does this happen with a stock ECU; always looking to improve I'll go ahead and include a 15a for everyone!
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
