Just ordered a Turbo Kit from TurboPerformance Works
Old Jan 1, 2004 | 12:21 PM
memo3's Avatar
Thumbs up Just ordered a Turbo Kit from TurboPerformance Works
After making some researches online, I decided go with Performance Works' Turbo Kit.
I talked to Nick on the phone and he was an extremely helpful guy. He knows what he is talking about. You can basically ask him anything you want to know.
He gave me an excellent deal (I am sure he will give you the same deal as well, just give them a call) and he said all the parts will be ready in less than 3 weeks and they can do the installation in two days and that is because they will be tuning the S-AFC for the new turbo. I can't wait to get everything installed and ready to go.
He said he will tune up my car when I go to their shop in Pennsy.
So far, I am really happy with the customer service. Pictures of their turbo kit installed on their Evo looks just great and shows the top notch quality.
If you guys are considering a turbo kit, I would say go with the Performance Works.
The Customer Service is great! Ask for Nick when you call the shop and he will answer your questions and help you on the phone all day long if he needs to.
I just wanted to share my thoughts about their service since they are new to the Evo forums.. and I will update you all once my turbo kit is installed...
Thanks!
Memo
BTW, That is what included in the Kit:
You don't have to get everything all at once of course! But that's what I got from him so far;
321 SS custom tig welded manifold (laser cut head and turbine flange)
External minigate rerouted into the DP or dumped directly into the atmosphere
Custom TO4E standard cartridge turbocharger w/ 4 bolt true 3" discharge and downpipe.
Integrated 3" DP and O2 bung for factory or WB fitments.
Dp will come flanged to fit any stock or aftermarket exhaust system. (It is made from 321 stainless mandrel bent tubing. Do not confuse them with 321ss cast elbows, that have a tendancy to crack under extreme heat)
Oil line kit that routes from existing stock locations.
Water line kit that reroutes from the existing stock inlet and outlet facility.
Turbo Kit w/ Front Mount Intercooler and piping-
Turbo kit above
Custom FMIC utilizing efficient bar and plate design.
The IC assembly is good for power levels in upwards of 700whp depending on the vehicle modifications.
321 SS 2.5" lower IC piping with appropriate Turbonetics couplings and T-clamps
321 SS 2.75" IC discharge piping with appropriate Turbonetics couplings and Tclamps
Tig welded BOV or Bypass valve flange welded to the piping.
Raptor BOV from Turbonetics
New SS battery Tray and tie down
Various vacuum lines , bolts, washers, and associated accessories.
Fuel Pump
Injectors
ARP head studs
S-AFCII
PeakBoost
75
Nov 20, 2011 07:57 AM
BenJ
65
Oct 11, 2009 08:12 AM
evane
Nov 12, 2008 10:47 PM
RnR Racing
141
Feb 22, 2006 09:27 AM
