Ryu's built motor thread (Sponsored by MAPerformance)
Old Aug 22, 2011 | 06:26 PM
RyuEvoIX's Avatar
It's been a long hiatus since late October of last year when I broke into the 9 second range with my factory motor. A few days later during cruising one of my factory rods finally gave out after years of 500+whp abuse on a daily basis. Go Mitsu Shortly after I was contacted by Chris Carey, President of MAPerformance, with a sponsorship offer to run their fully built motor setup. I graciously accepted Chris's generous offer. It took a bit of time to gather up the funds for the full build as I did not want to cut any corners or spare any expense but Chris and his team are very patient and easy individuals to work with. I'm happy to say the motor is finally here and ready for assembly. On to some pictures
As you can see, great care was taken for the shipping process. Thanks MAP
10:0:1 custom Weisco pistons with extra large valve relief ports.
Stage 3 MAPerformance ported Evo IX head
Exhaust ports with high quality MAPerformance port work
Intake ports with high quality MAPerformance port work
Beautiful bowl work w/ 5 angle valve job
Assembling the head
More updates to follow.
Old Aug 22, 2011 | 06:35 PM
9SecSLC's Avatar
Keep us updated! Which turbo are you going with?
Old Aug 22, 2011 | 06:37 PM
E-Spec@Tach Motor Works's Avatar
In on the first page!! Good luck!!
Old Aug 22, 2011 | 06:44 PM
RyuEvoIX's Avatar
I'll be sticking with the hta82 w/.63 hotside for now. I have a goal of 9.7@142mph in mind for this turbo setup that I believe I can reach without too much trouble. Ignition timing at peak boost (38psi) previously was 1 deg advancing to approx: 14 degrees out the top just to give an idea of what should be left in the tune on this turbo setup without the addition of the more efficient flowing head, slightly better cams, and higher compression as well. Once that goal is acomplished, then I'll be stepping up to an hta86 with a 9.3-9.4 @148-150mph goal.
Old Aug 22, 2011 | 06:49 PM
n2oiroc's Avatar
i wanna be sponsored.
*nobodyputsbabyinthecorner*
Old Aug 22, 2011 | 07:08 PM
SOEuro's Avatar
go 10s on stock turbo/stock block...that might help
Old Aug 22, 2011 | 07:11 PM
n2oiroc's Avatar
probably. im not bothering with that stock turbo jibber jabber. strait to 750whp!
op, congrats on the sponsorship! map is a fantastic company to work with!
Old Aug 22, 2011 | 07:30 PM
murlo26's Avatar
Wow! Looking great Ryu, GL with the goals.
Old Aug 22, 2011 | 07:39 PM
B.J.@ToxicFab's Avatar
Looks good, good luck sir...Looking forward to updates!
Old Aug 22, 2011 | 07:50 PM
RSMike's Avatar
Does anyone know what the "B" shaped exhaust port does?
Old Aug 22, 2011 | 07:57 PM
Ramonski's Avatar
Looks great bro and good luck...cant wait to see results...also bump for a LOCAL! Lol
Old Aug 22, 2011 | 08:34 PM
BigT's Avatar
It looks like it is a diversion of the exhaust gases to a straighter path out of the runner vs colliding into each other. Just a guess though.
Old Aug 22, 2011 | 08:40 PM
RyuEvoIX's Avatar
This would be my reasoning as well.
Old Aug 23, 2011 | 02:14 PM
ChrisCarey's Avatar
Looking good sir, can't wait for it to hit the drag strip!
Old Aug 23, 2011 | 02:42 PM
RyuEvoIX's Avatar
Thanks Chris. I can't wait to get back out to the drag strip to accomplish my next set of goals. By the looks of the high quality motor work by your company, I don't think it will be too terribly hard to accomplish them.
