Bent shaft on 71hta
Old Sep 4, 2011 | 09:55 AM
211Ratsbud's Avatar
Bent shaft on 71hta
I have just purchased and installed a 71hta, along with my homebrew oil line. I primed the turbo, it had good oil pressure, and within minutes of driving the tell tale whining of compressor wheel touching housing was evident. I pulled my fp84mm intake, and it was evident that 3 blades have been worn against the compressor housing, and the shaft is visually bent. What gives?
Old Sep 4, 2011 | 10:58 AM
acssa's Avatar
new or used?
Old Sep 4, 2011 | 11:15 AM
211Ratsbud's Avatar
New rebuilt by fp from a fp white
Old Sep 4, 2011 | 11:45 AM
211Ratsbud's Avatar
http://www.youtube.com/watch?v=vRqpb...e_gdata_player
Old Sep 4, 2011 | 12:05 PM
mt057's Avatar
Does it have shaft play? Seems to be spinning ok but it is hard to tell from the video. Can you pull it in and out? How much does it move side to side while gently moving it?
Old Sep 4, 2011 | 12:41 PM
211Ratsbud's Avatar
Roughly an eighth side to side. No thrust play
Old Sep 4, 2011 | 12:50 PM
B.Prug87's Avatar
if you bought it from FP why not contact them and see what they can do?
Old Sep 4, 2011 | 12:51 PM
mt057's Avatar
Have you had the surge cover on it before?
Can you take a pic of the damage blades?
Old Sep 4, 2011 | 01:03 PM
211Ratsbud's Avatar
I've already emailed them, won't get a response til tuesday. The turbo is fresh from fp I just put it on
Old Sep 4, 2011 | 01:45 PM
4g63evoeight's Avatar
i'd assume FP will take care of you but they might say something since you were using your homebrew oil feed line kit, but who knows
Old Sep 4, 2011 | 02:48 PM
Kracka's Avatar
Originally Posted by 4g63evoeight
...you were using your homebrew oil feed line kit
Old Sep 4, 2011 | 02:51 PM
211Ratsbud's Avatar
I guess its just a frustrating experience after 3 months of.saving for parts and rebuild
Old Sep 4, 2011 | 02:53 PM
Kracka's Avatar
Send it in to FP and hope they warranty it, and either way buy their oil line or at the very least use the stock oil feed instead of some homemade thing that can be brought into question. FP doesn't require their feed line for the Green or smaller.
Old Sep 4, 2011 | 03:43 PM
sparky's Avatar
Such a bummer, Ratster
Old Sep 4, 2011 | 04:19 PM
marrrk's Avatar
i would appreciate it if you could keep us informed on the whole turn around from fp and let us know how it preforms after the 2nd rebuild
i went thru two old style greens and i've been on the red for like 2 years, so any info would be great. good luck, hope your back up soon.
