Torque on main studs
Old Sep 4, 2011 | 10:00 AM
evoshawn20's Avatar
I bought arp main studs and i was wondering how much i need to torque them down?
Old Sep 4, 2011 | 11:08 AM
familymr's Avatar
60ft lbs in 3 steps
Old Sep 4, 2011 | 07:00 PM
THUB's Avatar
^ That. Make sure to use the arp lube or the torque spec is higher.
Old Sep 7, 2011 | 09:33 AM
devoadam2's Avatar
u might wanna check clearence on main bearings since stock bolts hold it to 40ftlbs ,had issues with a line hone on few engines
Old Dec 24, 2011 | 02:01 PM
wtf_is_a_evo's Avatar
not the jack the thread but what do you mean by that just have the mains line honed and fix the problem? or is there somthing i am missing reason why im asking this is i just destroyed my main bearings with 1,000 miles on my engine, and i want to make sure i do it right this time.
Old Dec 26, 2011 | 10:52 PM
mrg72433's Avatar
Does anyone have a answer to this guy? I would also like to know
Old Dec 26, 2011 | 11:24 PM
WHTEVO's Avatar
You are tightening the main caps tighter, which changes the clearances for the bearings. You will want to check your clearances with it torqued down, and adjust as needed to get the clearances you want. Good luck.
Aaron
Old Dec 27, 2011 | 11:01 AM
n2oiroc's Avatar
my engine builder went 60ft/lb with arp lube.
Old Dec 27, 2011 | 02:27 PM
Aaron
so it would be best to take everything to a machine shop, and let them do that or is there some kind of guide as to what i should be looking for?
Old Jan 3, 2012 | 03:56 PM
evolvd276's Avatar
what would be a good main cleanance just to check
kaj
22
Jan 27, 2019 12:23 AM
talonkev
May 3, 2017 06:16 AM
nos51
22
Mar 22, 2016 09:02 PM
ant_turbo
14
Jul 4, 2012 06:35 AM
evoyrrah
11
Apr 13, 2012 09:04 PM
