Please everyone chime in your EGT #'s
Old Jan 5, 2004 | 04:34 PM
Coolguy949's Avatar
What do you have to adjust by for having it after the turbo? What's the temp difference from having it on runner #1?
Old Jan 5, 2004 | 07:57 PM
bpclements's Avatar
Originally posted by stevEVO8
Just wondering, where did you tap you EGT probe?
What runner, how close, after the turbo....These all will affect EGt's a little.
Has anyone found which runner runs leanest yet?
Right there one runner number one.
Old Jan 5, 2004 | 08:19 PM
lilgsx's Avatar
Originally posted by boostedwrx
There is no device to measure knock count on the evo. I assume you were using dsmlink to get knock count out of your 2G. 15 degrees advance at redline isnt very good btw.
And just what would be good for a motor with more that 9.5:1 compression @ 26 psi? I could of put in a nother 5 degrees or so but the injectors were at 100 duty cycle so why waste the time qand money on the dyno. Yes timing is everything. 3 degrees on mine was like 30 whp. This was on C16 leaded race fuel.
Old Jan 5, 2004 | 08:21 PM
lilgsx's Avatar
After the turbo is not a very good spot at all. It has to be on the runners, just like the pic above. 1 inch could make a 100 degree diffrence. I believe the instructions tell you to put it 4"s away from the head.
Old Jan 6, 2004 | 10:32 PM
boostedwrx's Avatar
yea, closer the head the sweeter the heat.. or something heh
9.5:1 on a 2g block?? Dayumn...
Old Jan 6, 2004 | 10:53 PM
lilgsx's Avatar
no 6 bolt motor Pauter rods and ROSS pistons. Built by Magnus check by me!
Appauldd
Feb 15, 2017 07:05 AM
krillin
Feb 6, 2007 10:01 AM
tsherriff
Nov 9, 2006 03:33 PM
Sicktght311
Lancer Engine Management / Tuning Forums
13
Aug 21, 2006 12:42 PM
o4whtevors
46
Nov 9, 2005 08:37 PM
