Help trying to reach 400+Hp
Old Sep 22, 2011 | 04:57 AM
TheBoz's Avatar
Originally Posted by 1UpMoto
Again I will say "with the correct fail safes" it is perfectly safe.
I have the safe injection which will light up a bright led and let me know its not working and will also throw my boost down to wastegate pressure.
I also have the tephramod that will flash my engine light if I start knocking and also throw my boost down to wastegate pressure. Doesnt get much safer than that. I undertstand you had a bad experience with meth. But I have personally installed and tuned tons of meth setups and yes I have had parts fail plenty of times but thats why you take the extra step to make sure you have really good fail safes.
It seems like everyone either loves or hates meth.
I agree with this guy.
I was running AEM Meth Injection Monitor and AEM Meth kit. I made 400/400 on RRE's DynoPacks. Stock turbo, stock cams, stock Intake Manifold. Very silimar mods to yours. I was also running 50/50 and 91oct was my base fuel.
I have not had a single issue with the failsafes.
http://roadraceengineering.com/blog/?p=889
That is my car on the dyno. We tested every way for something to fail on the dyno. Kill the pump, over flow, under flow, low level, ect.
My failsafe map was my base 91oct safe map. So when the failsafe kicked in the car went to wastegate and ran unaltered 91oct tune.
Outside of running meth, you should be able to hit 400whp on a dynojet with the mods you listed. Have one of the skilled email tuners tune your car or take it to a real dyno tuner and they will get you there.
Old Sep 22, 2011 | 10:48 AM
SLO-EVO's Avatar
Mods list looks pretty solid. Your tuner would really dictate the HP numbers as each tuner has their own style. You have the right parts to achieve your goal IMO.
Old Sep 26, 2011 | 03:25 AM
harris81's Avatar
Agreed.
Old Sep 26, 2011 | 09:20 AM
rhd-jon's Avatar
Thanx man. As the time goes on i add a lil more to my list. Next month the car will get wrked done to it then off to tune it. As far a the tuner i rather not say who im going to cause im sure that'll start a whole new conversation lol. So i'll keep it on topic.
Old Oct 3, 2011 | 12:39 PM
Levar's Avatar
Veteran: Army
For 400whp on pump/93, I believe you are on the right path if that is your ultimate goal. If you do not make what you want, it would be easier at that point to identify the weak areas of your build and address them at that point.
Old Oct 3, 2011 | 02:34 PM
rhd-jon's Avatar
Just added a few more things like uicp/test pipe/02 housing and some other stuff....
Old Oct 3, 2011 | 05:41 PM
04EBevo's Avatar
I had those cams and didnt make it on 93, got closer to 400 with the cosworths and now at the same boost on e85 I am at 420.
Old Oct 3, 2011 | 05:49 PM
rhd-jon's Avatar
O yea ? We'll see what's up
Old Oct 3, 2011 | 06:11 PM
4RETECH's Avatar
I would suggest if sticking with a stock exhaust manifold, port it.
Get an O2 housing too.
I would recommend taking the cams out and going with Kelfords or GSC S2's.
But yeah, E85 would do you good.
Old Oct 3, 2011 | 06:33 PM
rhd-jon's Avatar
The car should be going in for wrk in 3 weeks if the funds are good i'll get another set of cams. Thank you guys for all the responses.
Old Oct 3, 2011 | 10:23 PM
Pale Horse's Avatar
Good luck, man!
Old Oct 4, 2011 | 02:11 AM
rhd-jon's Avatar
Thanx man.
Old Oct 18, 2011 | 12:19 PM
zeus1's Avatar
Originally Posted by rhd-jon
what's going on fellas. As the tittle saids my goal is to reach 400+ Hp
i have a 2003 evo 8 with 83k on the clock. My question is do you guys
think ill make it, or am i missing something. I will be keeping the parts i
have, but if im missing something i will be getting it. I'll be tuning on
93 octane. My set up is as follows. Thank you so much.
stock top n bottom
fp green turbo - New
hks 272 cams - Used
stock cam gears
Ets 3" i/c and pipping - New
evo 9 bov - Used
injen intake/hks filter -Used
3" hks exhaust - on car
1000 injectors - New
walboro 255 - New
stock manifold
arp head studs - New
oem head gasket - New
act Xt clutch/stock fly wheel - New
you might be close. my old set up was very similar to your list above. (i did have an 03 housing, 3.5 FMIC and test pipe( think you have a testpipe) BUT you have a new green and my old one was with the old green so that may make up for the aboce differences in mods. below is an overlay of my old set up vs new. hope this helps.
old set up (new set up in sig, major changes were cams, and turbo and bigger injectors to support
Built 2.0 Shortblock Stock Head BC Springs and Retainers|
|Power Mods|
|Original FP Green Stock WGA|
|Ebay TBE |APS DV|Joe P MBC|
|HKS 272 cams |
|Buschur; SS o2, Cone Filter,|
|Stock Exhaust Manifold|
|PTE 680 cc injectors|Walbro 255|
|ETS 3.5 FMIC, LICP v2 |Stock UICP|
Old Oct 18, 2011 | 12:48 PM
rhd-jon's Avatar
Thank you.
Old Oct 18, 2011 | 12:51 PM
KTriplett's Avatar
https://www.evolutionm.net/forums/ev...0-400-e85.html
Heres mine,yours is so similar. Your there or right on it! Good luck
